Results 1 to 10 of 20
Thread: HELP! Advice needed on phonostages with DECCA RIAA
    Default HELP! Advice needed on phonostages with DECCA RIAA
    Now that I'm well on my way to becoming a DECCA geek I got round to thinking if it might be a good idea to get a phonostage specifically built for DECCA RIAA or purchase one with the option already built in. So far I've seen the latest audio research reference pre-amp costing mucho dosh and the latest phonostage from ifi audio. Any other suggestions?
    PRE
    Croft preamps seem to be optimally set up to work with the Decca cartridge. Cant say the RIAA is bang on but funnily enough they sound very good indeed.
    I wonder why?
    I'm Jez.
    I don't know if it may be of any interest to you but I can build phono stages specifically for Decca (or any other) EQ and, in many cases, I could modify the EQ in an extant phono stage to be to Decca rather than RIAA standard.
    EDIT: Just a thought (I can't be bothered to revise the detailed history), IIRC the Decca eq would refer only to the correct replay of old records which were actually recorded to Decca standard rather than to RIAA standard and would have no bearing on the replay of standard records, even if using a Decca cartridge.
    It would only really be of use to someone wanting to get the exact correct response when replaying rare (?) archive records made between lets say 1947 and 1953 (a wild guess!) and then only if manufactured by Decca or a company licensing their techniques...
    I'm probably stating the obvious and teaching me granny to suck eggs there... and may even be less than 100% correct... but just saying
    If you're well aware of that and it is indeed what you wish to do then, as I said at the top, I can help
    Quote Originally Posted by Arkless Electronics View Post
    I'm fairly sure that's right Jez and that RIAA has long been standard across the board. I'm not aware of any other replay equalisation in common use.
    Hmmm I need to do my homework and come back to this one.
    PRE
    I'm Jez.
    Columbia, New Orthophonic, Victor, Old RIAA, Decca FFSS and FFRR all available! Thorns whittled to Shibata profile while you wait! (I may get serious enquiries from DL103 owners...) A huge untapped market awaits
    I'll get my coat....
    Do serious owners have DL-103's?
    (Marco will probably send the Denon brigade after me now )
    I'm Jez.
    I thought I would have had a bite by now
    Yep - I still use mine, as well as one of several EMTs
    What about the BBC equalisation curve? Can you do that as well?
