Hi all,
I'm looking to upgrade my system with a new amp.
I now use a Beresford TC-7520 DAC to listen to my Flac files I stream from my Mac using Cog and Airfoil.
Budget is around €500,- for something to replace my Onkyo TX-SV535 receiver.
Speakers are Acoustic Research Status S50 floorstanders, between the DAC and the receivers sits a Monster 250 Interlink and between my Airport Express and the DAC sits a Beresford Optical cable.
Speaker cable now is standard 4mm Oehlbach stuff, nothing fancy yet but this might change when I upgrade some more.
I have been looking at The Marantz MP6003 and the Rotel RA-04 for starters, but the the feeling came that you guys might know a bit more about what is good and what isn't.
I'm fairly new to hifi so just asking the experts
Thanks,
Martijn
