Seems to be a rarity these days..are there any stand mounts out there above 95 sens.......and floor standers. My Meishu has just about run in, yes after all these months..lovely amp....but I rekon 93 sens is really not doing it justice.....
Tim
Be lucky to find standmounts. Klipsch maybe.. My full range standmounts(homemade) are more. Probably 98/100.my twins probably same actually.
Your home made..what make ??????
Tim
As a general rule, the more efficient a speaker is the bigger it must be to have any decent bass extension. Hence very efficient stand mounters are virtually non existent. If you want 95dB + efficiency and good bass extension then think small wardrobe size....
Both have same telefunken drivers in.. Just the standmounts have 2. Not high watts but you dont need that as they go loud very quick. Theres pics of my latest ones on my gallery page. Just finished them a few days ago.. Quite nice sounding too ...the single driver ones are very sweet.
Ok, so any reasonable priced floor standers ????
Tim
Take a look at the Triangle range from France Tim.
They tend to be highish efficiency and are very nicely made. Floorstanders and standmounters. Some excellent reviews about.
Zu Audio is very high sensitivity & high impedance too, so an easy easy load. Like a lot of speakers they are marmite (I think most speakers are to be honest), but is an obvious choice aside from Klipsch & single driver (probably horn loaded) speakers.
Hoffmans Iron Law
Ah, the old meatloaf song
