Website: http://www.homehifi.co.uk
Website: http://www.beresford.me
Website: http://www.homehifi.asia
I'm yigit.
Is caiman and seg same size ? Both shows the same specifications on the web site.
I'm yigit.
I'm Tim.
Is the headphone section of SEG more powerful than the Caiman MKII? I have HD800s and the Camain II works, really needs an amp tho.
USB DDC is different now? Still need ASync-1 for higher bit-rate files?
The headphone gain on the SEG is adjustable. So you can increase it to taste. Scan from the beginning of this thread to see a picture of my SEG and my HD800 in use together. But neither the MKII or the SEG were designed to be headphone amplifiers. The headphone section is for low to medium levels of volume output. High volume output duty is reserved for my Capella headphone amp.
You don't need async-1 for higher bitrate files. It is quite possible to play those files with
the MKII and the SEG if you follow the info in the manual. The Caiman Firmware has its own USB handling software so that you don't to install any special drivers in Windows, MAC OS, or linux.
I'm Rob.
This is an initial assessment of the SEG that I received last Friday (thanks, Stan, for the prompt service!). By the way, what does SEG stand for?
After running it in over the weekend, I got a chance to power it up using my Anker power bank. Just a word on my set-up:
- streaming from my iTunes library is via a Raspberry Pi 2 + HiFiBerry Digi+ (the model with galvanic isolation), running Moode 2.6 (battery powered by the Anker)
- this feeds the SEG via co-ax connection and TosLink - I tend to use the co-ax though difficult to say that there's any audible difference
- the SEG feeds into a Naim NAP 100 power amp which, in turn, powers PMC TB2i speakers
Suffice to say the sound is amazing. Crystal clear, all manner of nuances within the music are clearly audible. Cymbals have a feathery delicacy and realism I've not heard through the system before. Bass - well, it has to be heard. Deep, powerful but controlled. Try out Hans Zimmer's soundtrack to Interstallar, or Bela Fleck's "Flight of the Cosmic Hippo" - I didn't think the PMCs could go that low :-)
I'm awaiting linear power supplies for the SEG and Pi, but in the meantime, this is definitely the best my set-up has sounded. If you want to hear what Pi + Moode can do, feed it into the SEG!
Now, what to do with my redundant Caiman II? :-)
Anyway, I thoroughly recommend the SEG. Congratulations, Stan, on another piece of magic at a very reasonable price. Hard to imagine this can be bettered, but knowing Stan, he's already working on it!
Rob
Bit-perfect Streaming: Raspberry Pi 2 & HiFiBerry Digi+ & MoodeAudio; DAC: Beresford Caiman SEG; Power Amp: Naim NAP 100; Speakers: PMC TB2i
Recording: Mics: 2 X DPA 2011C, 2 X Line Audio OM1, 2 X Line Audio CM3, 2 X Calrec CM652D, iSK SM168, 2 X Behringer C4; Recorder: Zoom F8; Zoom H4N; Interfaces/Mixers: Sound Devices USBPre-2, Behringer Xenyx 802, Monitors: KRK Rokit 6
I'm yigit.
I am planning to add Capella to my system as preamp to my roksan m1 power amp. I also have a radio, cassette and vinyl player too. So I'll use TC-7240 in between. I have the regular caiman mk2. My question is, should I switch to caiman seg or should I upgrade my caiman to GFU as I will just use their dac output only?
I'm yigit.
