Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 203
Thread: The TC-7535 Caiman SEG at a glance.
    He may be out of stock. He often takes stuff down if he doesnt have them in stock. PM Stan and he will tell you
    Are you now saying 15V is better due to the stonewalled 12V being removed from the SEG?
    It's purely based on some of the music I listen to through my HD800. Those cans have the best dynamic range any other headphones that I have ever tried or owned. When used with any of my 15V supplies the ear pressure from the headphones increases enough for me to notice it at high volume levels. The same goes for when listening to stuff with loads and/or deep bass. Did I mention that I gave away my twin 12" subwoofer?
    Quote Originally Posted by Getgaff View Post
    How do I order one of these? I can't locate it on the website.
    A few people have emailed me with a similar question. I am scratching my head a bit and wondering what it could be.
    The direct link to the shop is at http://www.homehifi.co.uk/PP/cartlist.html
    But keep in mind that is just the standard price. AoS members benefit from an AoS discount on any new product of mine. PM me if you are in the middle of evaluating the purchase of the SEG.
    Just looked for it on Stans website and its there.. First dac
    I'm john.
    Stan,
    The SEG sounds stunning, instant improvement over the Caiman II, but, you mention in the manual that the SEG will work with PSU's upto 13V but you mention using a 15B external PSU. I'm running a Anker battery and it's producing great results. Are you now saying 15V is better due to the stonewalled 12V being removed from the SEG? I'd be running the new 15V PSU through a PS Audio P10 so the power supply should be very clean and well regulated. I'd be happy to upgrade upto the PSU over the Anker battery for the price of the recommended 15V you highlight if you think that would be a better solution.
    Andy
    Hi andrew...I running a 15v psu it sounds excellent well worth a try
    jon
    I'm Bill.
    Looking for a DAC to use with my Lehmann Linear H/P amp and Sennheiser HD600's. Could the SEG replace my Lehmann and kill two birds with one stone?
    Quote Originally Posted by Bourneendboy View Post
    YES in a single word. I tried out the Senheister 1000 with the Lehmann H/P amp and it sounded SHIT! I'm extremely sorry if I offended you with that statement but that's my viewpoint for what it's worth. You can try Stan's products on 30 day return if not happy basis (I THINK). So you have nothing to loose.
    PRE
    I'm Bill.
    Sounds like it's not for me then.
    I don't have the HD600, but I do have a pair of the HD650. I use it quite a lot when doing paperwork and listening to music at the same time. I don't get that fatiguing with the SEG/HD650 combination that I often get with the Denon D7000 or HD800 after an hour or so of constant listening.
    Quote Originally Posted by jon1 View Post
    jon
    Thanks Jon, I suppose another box sitting on the hifi stack wouldn't go a miss!
    PRE
