Nice work Alan, go the whole hog and remove those front bolts.
Simon sq, what would you suggest? I suppose dome head bolts would look good, the fitted ones came with the enclosures.
Simon LDT, the sound is better than the AIR, in the areas you would expect with a move to monoblocks.
I am rather glad I took the trouble, the bass is more dynamic, the channel separation is better and the image is clearer
I like the bolts that you have, give it a slight industrial feel.
Well that's it then Kevin, off the menu for you
There is plenty of room to put the valve inside the case actually but I put them on the top for the aesthetics.
After realising that the heater was visible over its full length with these single triodes I also orientated the valve so the heater was visible from the front
I am only talking incremental gains of performance, so enjoy what you have
I'm Simon.
I like the look of the bolts on the front.
Hi guys is there a price for the firebottle monoblocks yet
Sent from my LG-H961N using Tapatalk
I think they are £1k.
Kevin
