Basically I have under consideration two arms and 2 carts to sort out for a friend's system
Whst cart to fix to which arm is the simple question?
The turntable is 'The MRM The Source
Thanks
DM
Thanks
DM
The Mission 774SM is in an altogether different league to any Rega in my opinion. It's a very high performance arm. Just make sure the bearings are sound. Moving freely and smoothly without slack.
I know the AT440MLB has fans, but my preference would be for the Dynavector. It's probably a better match for the 774SM anyway.
I've got a 774SM and it's a fine arm in the Ittok/Ekos league. I was using it with a Benz Wood SL so suits a decent MC. It's a Linn fit.
Thorens TD550, Ortofon 12", Ortofon Jubilee or Koetsu Black; Rothwell MCL SUT, VTL 2.5 pre, XTC POW 1 power; Naim CD5x; KEF Reference 3.2's; Van den Hul interconnects and speaker cables.
