He has various colours but this is the most popular...beige
http://www.ebay.co.uk/itm/1521324391...%3AMEBIDX%3AIT
The acrylic adhesive is way stronger than PVA. It's not particularly cheap, but it is excellent stuff. A repair is likely to be stronger than the surrounding cloth.
I've used it for all sorts of things. It bonds metal to metal well.
I'm Alex.
I'm Alex.
There are interesting grille cloths on US eBay sites. Worth a look if the original can't be sorted.
I'm Alex.
Thank you, I will pass that on to Peter.
Spendorman
The IIILZ's will need cabinet work too to sound any good, but that's another story - check for buzzy back panels.
Gonna take a wee bit more than new boxes to Patch the 10's.
They cleverly fitted a 2.5" LF cone voice coil to the standard tannoy 2" diameter Wave guide.
The resultant gap mismatch is right in the middle of the Prime Voice frequencies.
10's were Tannoys' stepchild product
Takes some skilled/careful machine work to turn a suitable ali transition piece... then fit it.
I'm Alex.
Why did they use a larger diameter voice coil than the other units?
Spendorman
The III-LZ was designed as a near field monitor, not a full range hifi speaker for far field listening. Tannoy wanted to preserve as much of the detail to about 1.5KHz as possible (ie within the middle of speech frequencies) so chose to run with a 2.5 inch voice coil for the LF for greater control and smoothness up to this point. They retained the 2 inch horn. The response problems didn't really happen until around 6KHz up to which point the III-LZ remains a remarkably smooth and linear performer, so it ticked all the right boxes for a near-field monitor and still does.
However, when applied to hifi use there is an issue above 6kHz where a phase inversion is present. This is caused by the gap between the end of the horn and the end of the voicecoil (ie opening of the main cone) where a short section of tube is parallel sided. It is this section of parallel tube which causes phase inversion of the HF unit. By then, the main LF does very little, and since both horns suffer the same phase inversion, the listener hears absolute phase inversion and not relative phase inversion, so for all practical purposes, it is rarely an issue except for measurement, and this is what may forget when describing them.
However, the issue can be resolved completely by smoothing he horn using something like a flexible car body filler (great care and skill needed!) so that its mouth exits at the end of the voicecoil tube.
For what it was designed for, the III-LZ remains fit for purpose although the cabs, as with most Tannoys, do benefit from some stiffening and improvements to internal damping.
