I believe.
Much like buy cheap, buy twice.
I believe.
Imho, it clearly depends on the mastering quality. I agree that it's hard, and it's still harder with AAC400VBR, especially when listening through headphones.
Nevertheless, for some albums, the difference is noticeable.
In any case, HD terrabyte value is melting like ice-cream in summer sun... no point in bothering about file size, really.
Dimitri.
George Orwell
What differences would an external DAC make to this? Would that highlight the differences more?
Dimitri.
George Orwell
I'm now using XLD to rip my CDs to iTunes in ALAC. Does anyone know how I can replace tracks I've previously ripped at a lower bitrate, therefore retaining any tags I may have modified?
Tags are embedded into the track files themselves. The best way to transfer them is to use one of Doug's Applescripts, here.
Simon.
Oh right. How come iTunes can replace tracks?
Hang on, I may need to check this....
Hmmm, I just ripped a track @ 256 with itunes, modified some tags and added artwork. I then re-ripped at ALAC and chose 'replace'. It replaced the track but kept the tags and artwork.
I then ripped with XLD with 'overwrite existing files' and 'add to itunes' selected. This added the track alongside my iTunes ripped one. The overwrite option doesn't seem to work.
Hi,
Are these the options you're talking about? I don't think they're linked. The "Overwrite" refers to when XLD rips to its own destination folder. The "Add…" simply passes the file to iTunes, I think, which deals with it according to its own settings---that's why you end up with a duplicate instead of a replacement.
Out of curiosity, how did you add the artwork---by dragging-and-dropping onto the Album Artwork Viewer or by the Get Album Artwork option in the Advanced menu? The latter adds the artwork to a folder (Music > iTunes > Album Artwork), and iTunes links to it when necessary; the former appends the artwork to the file itself.Hmmm, I just ripped a track @ 256 with itunes, modified some tags and added artwork. I then re-ripped at ALAC and chose 'replace'. It replaced the track but kept the tags and artwork.
Simon.
