Hello all,
A few weeks ago I purchased a pair a subs to use with my surround system. I got two as I've got a fairly big room, I read it was easier to integrate two subs than one and they were on special offer.
I decided that as I'd got two subs, I may as well try out integrating them into my system so that I can use them for stereo and surround duties to give me maximum flexibility. So I setup my AV amp so that it thought it didn't have a sub. This made it send the sub channel to the front L + R channels. I then got a couple of little adapters that allow you to connect two amps to one output so that I could connect both a sub and a mono block to each of the front pre-outs on the AV amp. So I now effectively had the subs connected as a pair of stereo speakers along with my front speakers running off the same output. This setup then allowed me to selectively add or remove the subs from the surround system and the stereo system.
I then played some music and fiddled with the crossover and phase settings on the subs until I was happy that they were integrated well. I settled on a crossover frequency of 65Hz and the phase set to 0 on both subs. This seemed to work well for music and movies until I started to try out a wider range of music. I noticed that some albums sounded bass heavy and some sounded bass light. So I immediately though that I must have got the phase set wrong, so I switched both subs to 180. This sounded right again at first but when I then swapped back to the album I'd used to first setup the subs, it sounded really bass light. I've done quite a bit of experimenting now and it seems that some albums need 0 degrees phase and some need 180. I really don't understand this as I would have thought the subs were either in phase or out of phase all the time depending on the setting but for some reason the phase relationship between the subs and speakers seems to change depending on the music I play.
I've also recently purchased a new pre-amp to finally separate my AV and stereo systems and I get the same problems with this and this has two separate lots of outputs designed for using in the type of setup I have. So I know it's not the AV amp or the double adapters that are at fault.
Does anyone know why I'm experiencing this problem or know of any ways to solve it?
I know I don't really need to use the subs and speakers at the same time when playing music and probably shouldn't from a purist point of view but I'd like to get it working properly all the same as it would simplify things and give me lots of flexibility. Also I do really enjoy a good bass fix now and then.
Thanks.
EDIT: I forgot to mention; the subs are positioned directly behind the L and R speakers to get them as close as possible to their partner speaker.
