Could anyone tell me how much it would cost to repair a Maranz CD 63 K1 signature the drawer will not lock shut and so will not read discs ! Is this a costly repair or should my friend take it up the tip ? Thankyou for your help
When you say 'not lock shut' do you mean it just sticks out a little as if something was jamming it just open?
There could be something stuck in the mechanism or a broken plastic tooth if the drawer unit uses plastic gears.
Worth having a good look around the mechanism, hopefully t will be something easy to fix.
Did it ever stick or jam? It may have jumped a cog
As above, likely a V minor issue.
Pop it open and sort it ? Simpler than dragging it to a shop.. and back, I would think.
I'm Adam.
I last had a CD63Ki about 10 years ago.
I remember the drawer starting to creak and I put a bit of vaseline on the drawer teeth and all was good again !
Adam.
I'm keith.
not got the Ki but have the cd63se and i remember when i bought it on ebay years ago the drawer wouldnt open. Took the top off blew a big lump of dust away and its worked perfectly since.
