Hamish,search Maplin for screened iec lead.This will be fine for powering your system.
Here's the Maplin one.. http://www.maplin.co.uk/module.aspx?moduleno=44118
But I like the look of these too.. http://markgrantcables.co.uk/shop/in...products_id=69
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
mark grant is top of my list so far for both interconnects and iec... unless anyone has a better suggestion
ali, i had looked at the maplin ones, but the mark grants are only a tenner more and for one reason or another i trust mark grants to be better even without direct personal experience
Mark Grant's will be (more than) fin imho. Just calculate the correct size: to do that, you need to place your system first.
Dimitri.
George Orwell
yup, im not buying anything until im in the house, il make do with what i have in the mean while...
just working out costs at the mo
Couldn't post the link as I'm doing this on my phone.Didn't know Mark made them TBH,so yes.they will be fine I'm sure.
If you want to save a bit with a Belden option I've been happy with Audio Friendly - http://cgi.ebay.co.uk/Belden-19364-M...item48342b7a07
I would be wary of the Cryo plugs - http://cgi.ebay.co.uk/Belden-19364-M...item334d2e24e8
if you use them in a distribution block (mains conditioner) they are too wide to have another plug next to them as they are bigger than normal.
Alex
Amplifier: Rega Brio R. Speakers: Spendor SP1. Cables: Various, mainly Mark Grant. Please see "about me" for the rest of my cr@p! Gallery
Hi Hamish
Getting dearer I know but not so much so, could be worth having a chat with your friendly Rega dealer and asking him to let you test out the new ones from the Isis/Osiris range, quite good I think @ £80 each. Worth a try.
Cheers
Hi Hamish,
While the other cable options look fine, I'd go with Mark's stuff as it's a known quantity and he's on-hand here to offer any advice, should it be necessary...
It'd also be good to give him the business, as he's member of AoS, rather than a 'stranger'
