Results 11 to 20 of 27
Thread: Devialet (+ News & Reviews) - At Musicraft (Derby)
    I'm Rick.
    Computer Audiophile reviews Devialet's Expert Le 200 Stereo/400 Mono
    http://www.computeraudiophile.com/co...00-400-review/
    The audiophile's benchmark. A superior phono stage for complex configurations. Additional connections. More power. May be chained to a second 200 to create a Dual Mono 400.
    The best Stereo, the first step towards the Dual Mono.
    2x200 Watts 6Ω
    THD+noise 0.001%
    Signal-to-noise ratio: 130 dB
    Advanced phono stage
    Devialet Expert
    http://www.theabsolutesound.com/arti...streaming-dac/
    The Absolute Sound reviews Devialet's Expert Le 200 Stereo/400 Mono
    Devialet Expert
    Devialet Expert Omnidirectional radio remote control
    Expert Le 200 - complete technical specifications -
    •Packaging contents:
    ◾1 Devialet Expert – Le 200 1 Expert Remote (3 AAA LR03 1.5V batteries)
    ◾1 power cable – adapted to the country
    ◾1 SD card for downloading configurations via the Configurator
    ◾User's manual for Devialet Expert – Le 200
    ◾1 warranty booklet (5 years)
    ◾1 microfiber cloth
    ◾1 pair of gloves for handling
    •Chassis carved out of a single aluminium block:
    ◾Black chrome finish
    ◾Dimensions: 383mm x 383mm x 40mm (l, w, h)
    ◾Weight: 5.9 kg
    ◾Sliding removable connector cover
    ◾Horizontal or vertical installation with automatic tilt detection
    •Electrical power supply:
    ◾Universal 80-265Vac – 50/60Hz
    ◾Power cable provided adapted to the country
    ◾Patented single stage switching mode topology
    ◾High power level: 600W continuous, 3000W peak
    ◾High output with power factor correction (PFC)
    ◾High resiliency to hazards potentially encountered on distribution networks : brownouts, quick transients, overloads
    •Inputs / outputs:
    ◾2.4GHz 802.11 b/g/n Wi-Fi input for the Devialet AIR universal streamer ◦Formats supported: 16-bit/44.1 kHz PCM to 24-bit/192 kHz PCM
    ◾RJ45 10/100 Mbps Ethernet input for the Devialet AIR universal streamer ◦Formats supported: 16-bit/44.1 kHz PCM to 24-bit/192 kHz PCM
    ◾USB Audio 2.0 asynchronous input/output ◦Formats supported: ◾16-bit/44.1 kHz PCM to 32-bit/192 kHz PCM ◾DSD64 1bit/2.822400MHz and 1bit/3.072000MHz
    ◾Special characteristics: ◾Very low latency ◾Bi-directionality for digitisation of the active source
    •S/PDIF TOSLINK optical connector: Formats supported:
    ◾16-bit/44.1 kHz PCM to 24-bit/192 kHz PCM
    •3.5mm mini-jack S/PDIF optical + RS232 connector:
    ◾Formats supported:
    ◾PCM 16bits/44.1kHz jusqu'à 24bits/96kHz
    ◾Device control via the bidirectional RS232 protocol up to 115200 bauds (documentation available via the configurator)
    •RCA 1 & RCA 2 connector (selected via the configurator):
    ◾1 or 2 coaxial S/PDIF digital inputs
    ◾Formats supported:
    ◾1 S/PDIF coaxial (RCA1) digital output
    ◾Formats supported: PCM 24bits/48kHz/96kHz/192kHz
    ◾Multi-room use and monitoring loop
    •Pre-amplified analogue output:
    ◾Set or variable volume ◾Output level up to 4 Vrms
    ◾Stereo/mono/left/right mixing ◾Available active filtering
    ◾WM8740 D/A convertor operating at 24 bits/192 kHz
    ◾Compatible with subwoofer, headphone amplifier, monitoring loop
    ◾May be activated / deactivated via remote control
    •RCA 3 & RCA 4 connectors (selected via the configurator):
    ◾Line-in stereo analogue input
    ◾24-bit/96 kHz or 24-bit/192 kHz sampling
    ◾T.I. PCM4202 A/D convertor
    ◾Accepts voltages up to +/- 10V
    ◾Maximum recommended level: 4 Vrms
    •Phono level stereo analogue input:
    ◾Accepts voltages up to +/- 100mV
    ◾Maximum recommended level: 15mVrms
    ◾Advanced conversion stage
    •1 or 2 coaxial S/PDIF digital inputs (Formats supported):
    •3.5mm mini-jack trigger connector
    •Speaker output:
    ◾Patented ADH® (Analog Digital Hybrid) hybrid amplification core
    ◾4 mm banana plugs or fork connectors
    ◾Maximum power of 2 x 200 Wrms under 6Ω
    ◾Adjustable from 30 Wrms to 200 Wrms via the configurator
    ◾Compatible with all speakers, from 2Ω to 16Ω
    ◾Short-circuit protection
    ◾THD+N (harmonic distortion) at full power: 0.001%
    ◾SMTPE IMD (intermodulation distortion): 0.001%
    ◾SNR (signal-to-noise ratio): 130dB (unweighted)
    ◾Thermal distortion: below measurement threshold
    ◾Output impedance: 0.001Ω
    ◾Passband: DC–87kHz (-3dB), DC–60kHz (-1dB), DC–30kHz (-0.1dB)
    •Phono stage:
    ◾Cells supported: MM/MC
    ◾MM sensitivity of 1mVRMS at 15mVRMS
    ◾MC sensitivity of 100 μVRMS at 5000 μVRMS
    ◾256 combinations for the resistive/capacitive charge of the cells
    ◾13 equalisation curves available
    ◾Specific menu for dynamic adjustment of all these settiings
    •Preamplifier & main digital/analogue convertor:
    ◾Patented Magic Wire Digital / Analogue Converter, D/A T.I. PCM1792
    ◾Unique high-precision MasterClock with very low jitter: 2ps rms
    ◾Conversion of all inputs into 24-bit/192 kHz
    ◾Built-in DSD / PCM conversion
    ◾SAM profile via configurator
    ◾Available active filtering on all analogue outputs via configurator
    ◾Volume control in increments of 0.5 dB
    ◾Volume adjustment range: -97.5 dB to +30.0 dB
    ◾Bypass/pass-thru mode available input by input
    ◾Balance adjustment
    ◾Tone control: bass +/-18 dB, treble +/-18 dB with variable frequency cut-off via configurator
    •On-board intelligence:
    ◾SD card connector for software updates and configurations
    ◾3 SHARC DSPs (400 MHz)
    ◾1 x 16 MHz RISC processor
    ◾4 x 40 MHz RISC processors
    ◾1 x 64 MHz RISC processor
    •Omnidirectional radio remote control:
    ◾Chassis carved out of a single aluminium block
    ◾Dimensions: 114 mm x 114 mm x 34 mm (l, w, h)
    ◾Weight: ? Kg
    ◾Requires 3 AAA batteries (1.5V LR03), provided – service life of a set of batteries: 2 years
    ◾No peering required
    ◾Ultra responsive, latency < 3ms
    ***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
    ***** https://www.facebook.com/MusicraftUK *****
    ***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
    Thanks
    Rick @ Musicraft
    Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
    I'm Rick.
    Stereotimes reviews Devialet's Expert Le 200 Stereo
    http://www.stereotimes.com/post/devialet-200
    2x200 Watts 6Ω
    THD+noise 0.001%
    Devialet Expert
    Devialet Expert
    ◾1 microfiber cloth
    ◾Weight: 5.9 kg
    •Inputs / outputs:
    ◾Formats supported:
    ◾Formats supported:
    •Speaker output:
    •Phono stage:
    ◾Balance adjustment
    ◾Weight: ? Kg
    Thanks
    Rick @ Musicraft
    I'm Rick.
    AV Hub reviews Devialet's Expert Le 200 Stereo
    http://www.avhub.com.au/product-revi...-review-400516
    http://i.nextmedia.com.au/Assets/Dev...oEsoterica.pdf
    2x200 Watts 6Ω
    THD+noise 0.001%
    Devialet Expert
    Devialet Expert
    ◾1 microfiber cloth
    ◾Weight: 5.9 kg
    •Inputs / outputs:
    ◾Formats supported:
    ◾Formats supported:
    •Speaker output:
    •Phono stage:
    ◾Balance adjustment
    ◾Weight: ? Kg
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Audio Stream reviews Devialet's Expert Le 120 Stereo
    http://www.audiostream.com/content/d...e2m7yhFLrrg.97
    Devialet's promise of uncompromising performance. The 120 incorporates all Devialet audiophile technologies and offers an extraordinary wealth of connection options for all your sources. The point of entry into the world of audiophile sound.
    2x120Watts
    THD+noise 0.001%
    Devialet Expert
    Devialet Expert
    Expert Le 120 - complete technical specifications -
    ◾1 Devialet Expert – Le 120 1 Expert Remote (3 AAA LR03 1.5V batteries)
    ◾User's manual for Devialet Expert – Le 120
    ◾1 microfiber cloth
    ◾Weight: 5.65 kg
    •Inputs / outputs:
    ◾2.4GHz 802.11 b/g/n Wi-Fi input for the Devialet AIR universal streamer - Formats supported: 16-bit/44.1 kHz PCM to 24-bit/192 kHz PCM
    ◾RJ45 10/100 Mbps Ethernet input for the Devialet AIR universal streamer - Formats supported: 16-bit/44.1 kHz PCM to 24-bit/192 kHz PCM
    ◾USB Audio 2.0 asynchronous input/output - Formats supported: ◾16-bit/44.1 kHz PCM to 32-bit/192 kHz PCM ◾DSD64 1bit/2.822400MHz and 1bit/3.072000MHz
    ◾Formats supported:
    ◾PCM 16bits/44.1kHz to 24bits/96kHz
    ◾Formats supported:
    •Pre-amplified analogue output (optional):
    •Speaker output:
    ◾Maximum power of 2 x 120 Wrms under 6Ω
    ◾Adjustable from 30 Wrms to 120 Wrms via the configurator
    •Phono stage:
    ◾Balance adjustment
    ◾Weight: ? Kg
    Thanks
    Rick @ Musicraft
    I'm Rick.
    The Devialet Expert Remote Control
    The weight of audiophile refinement.
    Carved out of a single aluminium block, the Expert Remote enables you to drive your system with unparalleled finesse.
    Responsive and precise, the Expert Remote offers the best audiophile experience.
    Using zero latency radio transmission technology, the Expert Remote is fully omnidirectional.
    Devialet Expert
    Once one recognizes volume control is the most frequently used operation on any hi-fi stereo system, the remote control function takes on critical importance.
    Traditional infrared technologies are slow and very limited in terms of directivity: pointing is necessary and it often requires many tries to achieve the desired sound level. Smartphone-based control applications also have their limits: unlocking time, frequent battery recharging, requirement of a network infrastructure with establishment of a connection.
    The Devialet remote control elegantly addresses all of these issues:
    • Its radio link operates in the 2.4 GHz band with a range of frequencies: it is compatible worldwide.
    • Omnidirectional operation: no need to point! The range in the actual environment easily reaches 10 metres, much more in an open field.
    • No complex peering mechanism is required: it operates immediately.
    • Latency is so low (approaching 3 ms) the control seems more fluid than if the buttons were located directly on the associated Expert system.
    • Its energy consumption is incredibly low: the service life of a set of AAA batteries is between 2 and 5 years.
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Tone Publications on Devialet's Expert Le 120 Stereo
    http://www.tonepublications.com/review/devialet-120/
    2x120Watts
    THD+noise 0.001%
    Devialet Expert
    Welcome to the world of Devialet
    Devialet Expert
    ◾1 microfiber cloth
    ◾Weight: 5.65 kg
    •Inputs / outputs:
    ◾Formats supported:
    ◾Formats supported:
    •Speaker output:
    •Phono stage:
    ◾Balance adjustment
    ◾Weight: ? Kg
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Devialet are exhibiting at the Indulgence Show - Novotel London West, London, UK. 14-16 Oct, 2016
    Devialet Expert
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Steve Huff Photo reviews Devialet's Expert Le 200 Stereo
    http://www.stevehuffphoto.com/the-de...at-its-finest/
    2x200 Watts 6Ω
    THD+noise 0.001%
    Devialet Expert
    The world’s most critically acclaimed start-up for the excellence of its innovations in sound technologies 58 Awards and 107 Patents
    Devialet Expert
    ◾1 microfiber cloth
    ◾Weight: 5.9 kg
    •Inputs / outputs:
    ◾Formats supported:
    ◾Formats supported:
    •Speaker output:
    •Phono stage:
    ◾Balance adjustment
    ◾Weight: ? Kg
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Part Time Audiophile reviews Devialet's Expert Le 200 Stereo/400 Mono
    https://parttimeaudiophile.com/2015/...t-200-and-400/
    2x200 Watts 6Ω
    THD+noise 0.001%
    Devialet Expert
    Devialet is a French company created in 2007 from the encounter of 3 complementary and explosive expertise: Pierre-Emmanuel Calmel, an engineer, Quentin Sannié, a visionary entrepreneur and Emmanuel Nardin, a designer of excellency.
    Together they founded Devialet, Ingénierie Acoustique de France
    Devialet’s origin: an invention that revolutionized sound processing.
    Pierre-Emmanuel Calmel invented a revolutionary technology that transformed sound amplification: The ADH Intelligence. The first hybrid technology that associates the preciseness of Analogue amplification (Class A) to the power of Digital amplification (Class D) allowing Devialet products to reach a never heard before sound quality.
    Why Devialet?
    The name Devialet refers to Sieur de Vialet, engineer and companion of Diderot, who participated in writing some articles for the « Encyclopédie Française ».
    The philosophy of Enlightenment is indeed at the heart of our profound inspirations for the Brand: the technological progress makes the Man better. With emotion, essential component of Devialet’s listening experience.
    Devialet Expert
    ◾1 microfiber cloth
    ◾Weight: 5.9 kg
    •Inputs / outputs:
    ◾Formats supported:
    ◾Formats supported:
    •Speaker output:
    •Phono stage:
    ◾Balance adjustment
    ◾Weight: ? Kg
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Devialet, the movie 30s HD
    https://www.youtube.com/watch?v=gF7zyijRM7c
    Devialet Expert
    Why Devialet?
    Thanks
    Rick @ Musicraft
