Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: DIY 'Hydra' mains lead
    danilo Guest
    Wink
    Nice bit 'o craftsmanship there, oddly attractive as well.
    Seems as a whole lotta work though
    I'm lazy and just buy/use these.. 2 for 10$
    I'm Deleted.
    Nice one . I'm thinking of building one of these . Won't be as nice as yours cosmetically though .
    Well the cosmetics do nothing for the sound . Actually, I'm not sure silicone is such a good idea as it will take a very long time to set. You can buy the potting compound quite easily from eBay.
    Account Deleted
    I'm Brian.
    OK thanks Mark .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    I'm Deleted.
    Default DIY 'Hydra' mains lead
    Quote Originally Posted by danilo View Post
    You are quite right, it is a whole lot of work - bit of fun though .
    The problems with the extension lead you show are 1/ the neon indicator is considered a no no and is often removed, 2/ there are more connections in the line and 3/ it isn't star earthed/wired. A lead like the one I have built is specifically intended to overcome these points.
    Account Deleted
    I'm Colin.
    What epoxy did you use? What is it dielectric breakdown voltage ? What is it fire retardant spec like ? is it self extinguishing ? And what is it temperature working range ?
    I am just think of safety and home insurance problems.
    So the CE specs would be useful, also note some Epoxy not only produce heat when setting can also give of gasses so ventilation is recommended, and just another point you covered the connections in tape some tape reacts with other plastic to become brittle and even in rare cases liquid, so the tape spec would be cool to have. The next thing is the epoxy Hydroscopic some are so water ingress may happen.
    Reaction between plastic like Polystyrene and PVC as in power cable in polystyrene boxes and loft insulation striping the cover of in time another fire risk.
    Take care Col
    I'm Deleted.
    I used a product called PX-700K-1 made by Robnor Resins. You can find the Technical data and material safety date here if you really want to:
    http://www.robnor.co.uk/robnor-produ...plication.html
    Manufacturers summary description:
    High electrical insulating characteristics
    High adhesion
    Low shrinkage
    Good thermal conductivity
    UL94 V-0 @ 1.5mm
    Excellent chemical & water resistance
    Does not contain halogens
    As you can see, water ingress is not an issue but why would it be - a bunch of 13A sockets in a plastic box is more likely to suffer water ingress.
    Some info on the electrical tape used (prior to being encased in the above resin):
    http://www.hellermanntyton.co.uk/sit...5x10/710-00104
    I'm quite happy that my cable is at least as safe as any other - but thanks for the concern.
    Account Deleted
    I'm Colin.
    As you can see, water ingress is not an issue but why would it be - a bunch of 13A sockets in a plastic box is more likely to suffer water ingress..
    But the 13Amp socket is in free air without the possibility of osmosis but encapsulation can and does cause problems we had that on the Euro Fighter, fixed now phew. So sometime low shrinkage can add problem when use other plastic as the epoxy heats and the cools gaps become apparent , a slight problem.
    You basic idea is bloody good I was just being over careful.
    The Robnor products are very good good choice.
    This is worth noting on there spec:-
    Causes skin irritation. May cause an allergic skin reaction. Causes serious eye irritation.
    Harmful to aquatic life with long lasting effects.
    http://www.robnor.co.uk/images/safet...X700K-1_BK.pdf
    http://www.robnor.co.uk/images/techn...d/PX700K-1.pdf
    I'm Deleted.
    Colin, each joint is fully soldered, wrapped in insulating tape and then fully potted - hopefully that is sufficient (it will only ever be used indoors and unlikely to see combat ).
    Account Deleted
    I'm Colin.
    Combat, it would win I am sure, I will duck quickly he he
    I'm Simon.
    Mmm glossy and mattness in one toy.
