Page 89 of 117 FirstFirst ... 3979878889909199 ... LastLast
Results 881 to 890 of 1162
Thread: LENCO - GL75 Project
  1. #881
    I'm Gary.
    Thanks Geoff but I'm busy changing other parts of my system at the moment , costing a bit at the moment .
    other parts.....like?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  2. #882
    Tonights Update - The Reference Lenco Pt XXXX - End game.
    I decided to concentrate on getting the tonearm mount sorted today. So I have a couple of pics to highlight whats been done. Firstly I decided to slightly modify (for a change) the drill holes. I made them slightly wider than the mounting threads so that any resonance from the top plate was not passed into the threads and therefore into the tonearm. I additionally started to add another layer of sorbothane under the wide based washers, I have this sitting around and it's collecting dust in the tool box so why not use it up? I had to make three new thread mounts and being a bit of a packrat helped. I'd kept several very long bolts thinking that they may be useful and low and behold here they are slightly modified.
    This is just a quick shot on the top of the top plate showing the newly installed tonearm mount. It took a little trial and error before it finally slotted in. This additional height should enable better VTA alignment for future cartridges.
    I have the small matter of filling in the speed selector switch. This is going to be a visit to Halfords for some more filler and then a quick respray, fortunately I still have enough supplies to do the job.
    The last major job is getting the motor mounting springs under the correct tension so that we have a nice silent motor and then its just a case of properly mounting and bolting the 75 alongside the Jolly bearing. The tonearm should fit in straight in and it's been properly aligned and setup since last time. I do have a funny feeling about the tonearm cable not fitting properly, I think this could be the fly in the ointment. So I could be spinning vinyl again on the 75 in the next 3-5 days and then I think I'm having a rest for a while until I can think of some other mad stuff. As ever, stay tuned.......
    PRE
  3. #883
    Tonights Update - The Reference Lenco Pt XXXXI - So near yet so far.
    The Lenco is now fully populated and mounted back into it's plinth. It runs to speed and the motor is nearly silent again. I've always had an issue with one of the front motor springs and suspect that it could really do with replacing but with a little tweaking I can get the motor to run silent within a whisper. Now, I've decided to get the Alphason tonearm fully serviced, re-wired and fettled to ensure I get maximum performance from the old girl. This means that the arm will have to go to J7 @ audio origami as do all my arms purchased 2nd hand. The service usually take a couple of weeks which is no great shakes as I have a couple of other decks to play around with and this time gives me the oppotunity to listen to some recently purchased muzak. Now the sad bit this could mean the end of the road for modding the little Lenco. I honestly dont think that there is much further to go. I think that I might publish another update or two just to detail how the deck sounds and then I think that's that!
    As ever, stay tuned..............
    PRE
  4. #884
    I'm Brian.
    Aw...that's a shame Andy . This has been a great thread and I've really enjoyed reading it
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  5. #885
    Theres still life in old thread yet Brian. I have a few bits and pieces still to do and the thread might get updated as I mess around with new cartridges etc.
    PRE
  6. #886
    I'm Keith.
    It's been a good read Andy. I will no doubt be implementing some of your mods as and when I finally get around to replinthing my 75. I already have one of Jolyon's excellent bearings and A Norbert idler wheel; just need the weather to pick up so's I can use my workshop[ back garden]
  7. #887
    I'm Brian.
    I always keep my eye on this thread Andy . I've really enjoyed reading it too and will use it as a guide when I buy my 2nd GL75
    Regards
    Brian
  8. #888
    Sure plenty folk will
    Tonights update - The Reference Lenco Pt XXXXII or life the universe and everything Lenco....
    Wiring, snake oil, complete Hollocks or positive sonic improvement? I have no clue, I just like the idea of decent honest good quality components at a reasonable price. So I decided to replace my power lead from the Speed controller to the PS Audio P10 power regenerator . So, I went to HiFi collective and ordered a couple of goodies
    and a couple of meters of my favourite screened power cable, good old Belden! The old power cord has now been relegated to powering my CD player. Gone is the "high content copper" components and now everything is 100% copper. I've got some silver wire kicking around so I may rewire the deck in pure silver which will probably not do anything, but you never know! So, I've done just about as much as I can to get the best quality "juice" into my deck. Decent conductors with a clean, filtered, reconstructed power supply.
    As ever, stay tuned.....................
    PRE
  10. #890
    I'm Torsten.
    Hi Andrew,
    congrats to your very nice project !
    I've read through all of it with great pleasure and also particularly your pictures
    are well made and helpful understanding what you did and why..
    Between the lines I sense you had to have a certain patience with the timing of delivering of your bearing.
    Could I possibly ask you a favour ?
    Could you put him a short note via mail, asking him to get back to his German customer..?
    Sorry to bother you with this, but it would help me a lot.
    From the quality you seem very pleased with the Jolyon bearing..?
    That's good news at least,
    I'll enjoy reading your sonic results and thougths, especially in comparison to other decks you have experienced.
    Kind regards,,
    T
