Originally Posted by
brian2957
Andy I glued the inner piece back into the outer metal casing . This is what I have now after I pushed the inner cartridge back into the metal rectangular casing , after I cleaned everything up first .
TBH , looking at the state of it I think this has happened before and the person who sold it to me has dubbed things up in order to get rid .
The cartridge looks ok TBH it's the generator in the inner casing that's the most important thing. A lot of companies get rid of casing altogether, look at the A95 from Ortofon and some of the high end Van dan Hul carts, several thousand quid for a cartridge with no casing!! I hope the wooden headshell stabilises things for you.
brian2957
Well , I fitted the new 12mm ply baseboard today . Unfortunately this produced a problem . The motor was touching the base . God these little motors produce some amount of vibration . I had to fit 2 batons to lift the turntable away from the base . Once this was done I was rewarded with improvements in all areas and I'm well pleased . I have to say that you were right Andy , the flimsy baseboard was robbing the GL75 of some of its potential . Great upgrade
Welcome to world of turntable modding! I'm glad the mod worked. Thorens used to do the same mod with the TD150/160. I'm now beginning to believe that the Lenco really does benefit from careful vibration supression and added rigidity whenever possible. It should be possible for you to bolt your current bearing to the new base board, thus stiffening up the bearing even further, this should be pretty simple to do and not balls up the deck.
