Tonights Update - The Reference Lenco Pt XIV - More Fettling and a kick up the arse!!!
I've had some downtime and decided to do more research, get in contact with a few Lenco GURU's and kick myself up the arse and get a few little jobs done.
Tonight I decided that the tonearm cable needed a little fettling so I cleaned the RCA's and the earthing post. I've had the TYR tonearm cable for years and have never given it a clean and considering that it's been on my list of stuff to do for a while I thought I better get on with the job. I always polish with BRASSO and then clean away any residue with IPA and then finish cleaning with contact cleaner and cotton wool. The finished article.....
I recieved another package today and managed to complete another task on the list this time it was... platter dampening rings. I ordered these from eBay for £13 and they arrived 24 hours later, that's quick!! Why bother? Well, the platter did have some imperfections when I polished it and they do hide a multitude of sins as well as adding an additional vibration control to the deck. I've been a firm believer in dampening rings for a long time and utilise them on all my platters which are usually bloody big heavy metal things. I've used them on my 301 for quite some time and they add a small but worthwhile improvement and hopefully will give me a nice return for my investment. I used three on the Lenco top platter and should compliment the aesthetics of black top plate and silver tonearm. I've taken a quick snapshot of what the platters will look like once on the deck.
Now, the Jean Nantis TJN modded is either loved or loathed. Plenty of people seem to think it works others think it's complete bunkum. I decided to contact Jean and see how much this mod costs, well $75 is the answer and I honestly can't see how a couple of clips, some fine line and a small weight is going to cost that amount so it looks like I'm going to produce my own version. It's not high on the list of things to do at the moment and will only "live" on my Lenco if I can percieve a sonic improvement. Now to all those that think it's bollocks I agree that the theory is ropey but I still think it's worth trying. I'll probably start getting the bits together over the next few days/weeks and assess over Xmas to report my findings back. I've also contact Jean with regards the Post mod for the Idler arm. There seems to be several ways of doing this and I'm assessing which is best. I've tightened my idler arm slider as much as possible and it still rocks. It's designed to do this but it will produce idler wheel oscillation and instability when engaging the platter during operation.
As an aside I now need to start looking at coupling the top plate to the platter. I'm going to order some Marine resin and fill the top plate. I have a spare top plate to experiment with. This will add additional mass to the L75 and increase it's surface area so this will enable better coupling to the plinth. I will also fill additional holes in the top plate and determine where I can use some wood screws with washers to better couple the top plate to the plinth. So plenty to do over the next few weeks. I'll make a proper start with all this stuff probably in the new year. Let's just get the Jolyon bearing installed and have a listen to what we've produced so far!!!!
NOW Kai, some answers...
I got rid of the wheel oscillation buy using the Werner Idler arm modification which costs 7 Euro. It works by using 2 larger teflon washers to replace the much smaller versions supplied by Lenco. Werner also supplies a small locking collar to which enables a better fit betwee the washers and the idler wheel. The Teflon has a very low coefficient of friction but still need either greasing or oiling (depending on your choice) I used 3-in-1 oil and the wheel now functions silently and with no oscillation. You may also want to do the Post modification to the Idler arm slider as this is an area of idler wheel oscillation. I think "alignment" is bollocks . All you need to do is make sure that the platter rotates at 33.33 rpm with a vertical non-oscillating idler wheel. Well I think if your Lenco is working well then leave it alone. Hope this helps.
