Nice write-up again Andy . The only things I have done to my GL75 so far have been :
Stripped the bearing and fitted PEEK thrust pad and ceramic bearing . Lubricated with Lithium grease .
Fitted bearing collar .
Fitted new V-blocks to the tonearm .
Fitted a Shure M55E and basic Jico stylus .
Replaced the idler wheel and shaft ( there was a slight kink in the original shaft and the six hole idler wheel seems more substantial than the two hole one )
Fitted a little locking collar to the idler wheel which has removed a small amount of wobble .
Fitted large oak cones to the bottom of the turntable .
All these little tweeks have improved the turntable incrementally .
I take it the crystal mat is an improvement over the original one .
I'm trying to keep this GL75 as original as possible , however , when funds allow I will probably buy another one and follow the route you have taken with yours .
Good work Andy
