Page 29 of 117 FirstFirst ... 1927282930313979 ... LastLast
Results 281 to 290 of 1162
Thread: LENCO - GL75 Project
  1. #281
    I'm Brian.
    I'm using a lightweight cable at the moment and I'll have a look at the Belden cable when it arrives . The cable isn't fixed anywhere on the deck . Regarding vibration , have you applied any bitumen type material to the top plate ?
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  2. #282
    I think nice thin lamp cable would do the trick chaps, I am using it and it feels similar to the original stuff.
  3. #283
    I'm Brian.
    Mines didn't come with a mains cable fitted , so I wasn't sure . Thanks James
    Regards
    Brian
  4. #284
    Nope, no bitumen, dosen't seem to be well regarded over on LH, besides I'm still trying to get some ideas as to how this deck sounds. I don't want to over dampen. I've a birch ply plinth which sinks quite a lot of vibration, the bitumen might work well on yours, be careful it's a sod to remove, additionally this mod seems to be popular with the elastic band suspended suspension brigade
    PRE
  5. #285
    I'm Brian.
    Just a thought Andy . As I've had the misfortune to remove this stuff before I don't think I'll bother
    Regards
    Brian
  6. #286
    Sticks like shit to a blanket mate
    Agree with you there Andy about over damping - mine sounds very sweet without damping although all the rubber grommets under the top plate are still intact. I would really like to hear what the difference is between the standard plinth and a heavy modified plinth as I am not entirely convinced it makes a huge difference?
  8. #288
    I'm Brian.
    There's an answer to that ( it's called leading with the chin )
    Regards
    Brian
  9. #289
    there is none in my new speaks.... at mo anyways. Which are still sounding good. Need to get over there and see the Lenco .. must get off my derriere
    I'm not sure it's possible to 'overdamp' a turntable. After all, there are no benevolent resonances at this end of the system. If the cartridge, arm and arm mount interfaces are as rigid as possible, then surely the least resonance and vibration in other parts, the better?
