Page 28 of 117 FirstFirst ... 1826272829303878 ... LastLast
Results 271 to 280 of 1166
Thread: LENCO - GL75 Project
  1. #271
    I'm Brian.
    I have ear marked Saturday morning to have a go.
    OK James , please let us know how you get on .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  2. #272
    I'm Brian.
    Andrew , have you changed the phono leads and plugs ? I found that doing this made a difference also .
    Regards
    Brian
  3. #273
    I will pop the bearing in aswell
  4. #274
    I'm Brian.
    Remember the lithium grease
    Regards
    Brian
  5. #275
    what to the tonearm? I'm using a spare Nordost TYR tonearm cable I had, it's got eichmann silver bullets fitted. The power lead into the deck is just some power cable I had in the garage, the plug is a silver plated jobbie that I had sitting in my toolbox. I think the power filter will probably be the thing that improves the sonics. I'm not "big" into cables. I love Silver, I love Yannis cables, and all my power leads have decent heavy gauge copper that's well shielded, that's about it really.
    Looks like a trip to Halfords.
    PRE
  6. #276
    I'm Brian.
    Ooops ! Sorry Andy , I'm referring to the original arm , which you don't have .
    I'm going to order some Belden cable soon .
    Regards
    Brian
  7. #277
    Got a tube ready
  8. #278
    Belden cable for your power lead?
    PRE
  9. #279
    I'm Brian.
    Yes . I'm not sure if it will be a bit heavy for this application or not .
    Regards
    Brian
  10. #280
    My thoughts exactly, the weight of the cable may have some effect on the suspension springs which shield the top plAte from vibration, common wisdom is to use a light flexible power cord. Additionally don't fix the cable to the top plate as vibration from the power cord itself can get into the top plate through the motor it's better to let it dangle.
    PRE
