Page 20 of 118 FirstFirst ... 1018192021223070 ... LastLast
Results 191 to 200 of 1173
Thread: LENCO - GL75 Project
  1. #191
    I'm Deleted.
    The arm tube is titanium, the rest of it is stainless steel.
    100% Analogue
    Account Deleted
  2. #192
    I'm paul.
    My two penneth on the 401 v lenco subject. Assuming an arm change on the lenco to make a more level playing field as the 401 can have pretty much any arm. From experience to equal the 401 the lenco requires a lot of money thrown at it. The ptp plate is a big improvement, the speed change on the lenco is a bit Heath Robinson so Nigel's speed controller is very useful if you want to play 45 and/or 78, I don't believe it makes any difference to sound quality. The 401's speed change is reassuringly solid. I have owned both a 401 and lenco ptp, both used with an audiomods arm they sounded very much the same but the lenco with speed controller cost more. The lenco is more fun for the diyer.
  3. #193
    Quote Originally Posted by paulf-2007 View Post
    I agree with you on the speed change on the Lenco, it's quite Nobel to say the least and overly complex, too many parts which can transmit vibration into the chassis and platter. I'm not really looking to try and make a 401 "killer" I have a 301 which will trounce most 401's. I intend to do the PTP route at some point, probably next years project. I'm surprised you think that the speed controller adds nothing to the Lenco, I usually find note pitch improves and soundstage becomes more cohesive. The audiomods arm is a very good arm and I nearly bought one two weeks ago!!!! The Alphason is a straight drop in whilst the audiomods spindle to tonearm yoke apex distance is not correct by several mm's and can only be accompany with major top plate amputation or specific cut out into a plinth or separate tonearm pod. I think you have hit upon the essence of this lenco journey, it's DIY fun.
    PRE
  4. #194
    I'm Jez.
    I've wondered about the possibility of making a GL75 belt drive..... To the outer platter.
  5. #195
    I'm Christian.
    Quote Originally Posted by Arkless Electronics View Post
    Sacrilege! Well, at least it is not really in the Lenco spirit... But you can take the motor out of the plinth and use the idler wheel in the "rim drive" mode. That is what I do and I like it, though it is no oil painting.
  6. #196
    I'm Jez.
    Quote Originally Posted by Cristobal View Post
    Interesting bit of DIY!
  7. #197
    I'm jamie.
    Well the journey continues. The Speed controller is being made and now I have my dream tonearm for the Lenco. I've been after one of these for a LONG.... time and finally one comes up at a reasonable price. Ladies, the one and only Alphason HR100S. This example is a little rough and will be immediately sent upto AO for a full fettle and maybe a silver rewire . I see that a counterweight is missing and also the tonearm cable. I have a Nordost TYR tonearm cable floating around so I will hopefully push this back into action.
    Attachment 17849
    Attachment 17850
    Attachment 17848
    It's probably going to be mid-late september when this project is finally finished but we are getting to the finish line.
    ah i was watching that one,it still fetched big money despite the missing bits,let me know if you need any info on the bias weight size or the mounting collar
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  8. #198
    You now have a PM!
    PRE
  9. #199
    The alphason arrived today. Less grubby than in the pictures. I've spent this evening polishing the tonearm, greasing the tonearm raise mechanism and replacing some material that had worn off where the tonearm sits. The counterweight was filthy so this has been cleaned and I've covered up a few scratches in the tonearm. This is an early example No 1293 I think. I'm missiing a mounting collar so I shall have to fabricate one. I also need a anti-bias weight. This will be going upto J7 for a re-wire, service and replacement anti-bias weight. Jez no has all the bits for the Speed controller apart from knobs and case. Things are slowly getting there! I don't think I have much more to do apart from wait for all the bits to arrive and then enjoy the deck.
    PRE
  10. #200
    So near yet so far....
    A small update tonight on the Lenco project. I finally managed to get a bit of time together to bodge a quick arm mount for the Alphason. I mounted my old Shure M55E and got a side of vinyl playing, so the project finally produces it's first notes. Now I'll have to dismantle. The tonearm cable and Alphason are going to J7 @ Audio-origami next week and then it's a waiting for Speedy Steve to get back in contact. I need a new mounting collar and I might get some more counter weights made for the Alphason whilst I'm at it. The project will be finished when these several pieces of work have been completed and then it's just a matter of listen, enjoy and then plan some more upgrades! The speed controller is still being made.
    It's probably going to be a whole new plinth in 2017 and then maybe the PTP!
    PRE
