Think the source direct is just bypass of tone controls, but if the cd bit was converted the wires could be wrong way round
If CD is OK through other inputs, it is likely to be something minor. Could be that somebody has had a tinker on the CD Direct input and cocked something up.
If it's an eBay purchase. The seller has no option but to take it back unless a defect was mentioned in the description. It would be 'defective' or 'not as described'!
There was another one that just bypassed some of the amp...think it was pure direct or sommat
Just been searching and it seems CD Direct, Pure Direct and Source Direct all just bypass the tone controls. So I was talking bollocks. Precious little on the web about them though. Probably all on the dark net.
Hi Dan
The grand wazoo, also known as ChrisB or at the weekends I understand it's Juicy Lucy on TAS is able to help.
Let me know if I can help more.
Source: Heavily modified DDDAC using MacBook Pro.
Amplification: Pre amp-Stereo Coffee pre amp on steroids.
Power amp- Rather large Colin Wonfor Class A power Amp
Speakers: Lampizator P17 Open Baffles
Accessories: Klotz 500 DIY Interconnects & DIY speaker cable sounding better than anything commercial.
All powered from a Mother Trucker BPS with a dedicated consumer unit with 10mm armoured radial back to the house tails after the meter.
Pre & Power
Technics SUC 909U & Technics SE A909S
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Someone's buggered the wiring up - an easy fix.
https://youtu.be/ZCBe7-6rw4M
