Dimitri.
George Orwell
The iQ7 have gone to a new home. I couldn't bear their immense harshness any longer. The nail in their coffin was when I replaced them with my old K120 bookshelf Kefs on wobbly coffee tables for stands and sat back with my iPod remote in hand. what a difference, beautifully smooth, like the silk the tweeters are made out of. Next time I think I should steer clear of titanium or metal coated anything, I'll listen to myself.
As for what's replacing them, I've found a pair of K160 Kefs. With luck, they'll give me the small amount of missing LF I have with my K120s, however, compared with the iQ7 these have cost me nothing and if they don't work I'll use them for my Yule Log and buy some atacama's for my K120s ;-)
That's my update.......so far.
Steve
Life is not a trial run.
heard the iq9 once and was very impressed for the money
Eric Bibb
No I don't think they are harsh either. The IQ4 and IQ9 are better. The IQ7s just failed to be very inspiring. We sold most 4 & 7s for AV use with Yamaha or Denon amplifiers.
The IQ9 is a very good mass produced speaker.
Kef are a Chinese company now, still designed in the UK but thats all.
Are you using the original links ? If so bin them they are crap...either BI-Wire or make links out of the cable you are using. The 7's like to be a wee bit closer to a back wall than you might think. Make sure they are fully stable. level and only slightly toed in...only a smidge. Do not use QED Silver Anniversary speaker cable . Way to bright and thin. QED XT300 or 400 is a better match with these speakers or anything just the warmer side of neutral or neutral.
What amp etc are you using ?
Regards D S D L
Regards Neil
