Despite upgrading most areas of my system i just cant seem to let these babies go. They do so much right and are an audiophile bargain IMO / IME.
They were the first 'proper' speaker I'd ever owned and still continue to bring a big smile no matter how much I upgrade, they too just get better.
If you are unfamiliar with them, the sound is balanced, detailed, tight punchy bass, rather than low and weighty.
The Aerogel mid-bass driver is a peach portraying vocals beautifully as well as instrument textures, nuances and detail where the music is in the mids and imaging is superb. Very importantly non fatiguing - I can listen these for hours on end
They are solid and well built and in my view look good in small to medium sized rooms.
If I had to keep them then hey ho! no probs However ..........
If at some point I did scratch that itch what would you recommend as a genuine 'upgrade' 'improvement' over these ?
I'm after all the above in upgrade form
..... tricky ?
Spendors have been mentioned previously and caught my radar particularly the S8e's
Kef Reference maybe? which ones though ?
Any others ?
Keep the 752's ?.....
