Cat 5e Connection Advice.
I've just finished running a cat 5e cable through a tortuous route in my house (behind walls, through the attic, under the floor boards Aghhh!!) and now it's time to make the cable ends off.
Stage 1: One end is a Sky Ethernet Hub with a NAS device plugged in: the other (different room, different floor) is a Cyrus Stream X2.
My interpretation (courtesy of Wiki) is that I need to adopt a "Straight Through" cable configuration from Hub to Cyrus - same as a patch cable - rather than a "Crossover" configuration.
Is anyone able to confirm this for me please?
Stage 2: (sometime in the future)
Unplug the cable from the Cyrus and insert a "switch", then connect the switch to the Cyrus and put the NAS adjacent, connected into the switch. I can then take another lead off the switch and connect to a TV box or similar.
Again, are these "Straight Through" cable configurations?
Please go easy, vinyl was never this tricky.................
Source: Orbe SE / SME IV / Cadenza Bronze
Source: WD NAS / Cyrus Stream X2 / Chord DAVE
Source: Oppo UDP-205 (CD/DVD-A/SACD)
Amplification: Icon Audio PS 3 Sig Phono + Audio Research LS27 + Musical Fidelity A5cr Power Amp
Loudspeakers: ProAc Response D28
Cables/stands: Mark Grant G1500HD + Linn K20 + Cat 5e
Other bits: Okki Nokki keeping things clean
