OK; thanks. The Rp2 is the one I have.
BW
Bonky
BW
Bonky
My Gear:
Source component/s:
Cambridge CXC Cd player; Inspire Apollo deck + Roksan Nima arm + Ortofon 2M Black; Denon TU-580RD tuner; Logitech Squeezebox Touch. Rpi with Volumio. RME DAC.
Amplification: WD KEL84+ valve amp; Rega Brio, Quad 306 (DADA modded, - in reserve)). Trichord Dino2 & Dino+ PS;
Wiim mini, Wiim Pro, Wiim ProPlus streamers
Loudspeakers:
Living Voice Auditorium IBX-R2.
Q Acoustics 2010 in the 'study'.
Cables/stands: Chords; Van Dammes 4mm
Any other hi-fi bits:
Apple MacMini Pro; Senn HD598, 467,
Linear PSs for Rpi and DAC. Pure mains conditioning.
I'm Alastair.
There were similar arguments with the Squeezebox Touch. To be honest I could not tell the difference between WiFi and LAN on that either.
I have run RPi1 via LAN (USB output) and RPi3 via LAN and WiFi (SPDIF output via Digi+). In both cases I stream from a NAS. I cannot detect a difference between WiFi and LAN. You can also disable the Bluetooth in the RPi3, if you so wish. The WiFi on the RPi3 is very solid (and more stable than a WiFi bridge I had previously in the same location).
I run picore player and the RPi3 is powered by Li ion battery, which I suspect makes the most difference of all, as it did with the SBT.
Cheers
Alastair
RPI4/PI2AES running PiCorePlayer/LMS-> AQ Carbon AES -> Topping D90 DAC-> Khozomo Passive Pre-Amp -> 4x Temple Audio Monoblocks powered by 2xLiFePO batteries->Van Damme Black Bi-Wired to B&W 804 Nautilus and Sommer Carbokab 225 Interconnects
