On one of a pair of cables, there is no continuity between the plugs (earth). So taking apart the plug it looks like there is a bit of soldering to do
Inside the cable are two wires and a shield. One wire is obviously the signal, but what should be soldered to the plug (earth) - the other central wire alone, the shield alone or both the shield and central wire together?
