Results 1 to 10 of 13
Thread: Ultrasound - Stylus Cleaning
    I'm John.
    Default Ultrasound - Stylus Cleaning
    Has anybody ever cleaned a stylus in a jewellers ultrasound machine? Safe? Results?
    Cheers
    John
    Technics 1210/Mike New Bearing/Jelco SA750d/Goldring 2500/Paul Hynes SR5 21/27.
    Cambridge Audio 840c CD. Squeezebox Touch. Synology NAS.
    Teac A-3440.
    Beresford Bushmaster.
    Quad II monoblocks....Quad 44/405.....Croft Micro.....Cambridge Audio 840.
    Celestion Ditton 66.....KEF Reference One
    I believe its not safe. not tried it though
    I'd think the same. No stylus of mine will be going near an ultrasound cleaner.
    The AT 637 is advertised as an ultrasonic cleaner, whether thats true or it just vibrates at a rapid rate I don't know, but it certainly works on my cartridges, with a stroke of Stylast my needles seem to be fine, as for putting it in a jewlers ultrasonic machine? SCARY!!!
    cheers Al
    My system,
    Cartridges Lyra Delos, Audio Technica AT33EVmc, AT 24 mm
    Turntable Thorens TD 124 Mk2, in a Jim Campbel plinth,Audio Technica 1503 Mk3 arm
    CD player Technics SL-PG490
    Cassette deck Yamaha KX 530
    Moving Coil Amp Albarry MCA 11
    Pre-amplifier Albarry AP 11 (battery powered)
    Power amps Albarry M1108 Mono-blocs
    Speakers Allison 3 Corner units, Allison 6 stand mounted cubes
    Interconnects AVT Matrix 6 and OFC short ones
    Mains distribution Music Works Recoil 6 gang and mains leads
    Tables MusicWorks ReVo acrylic stand, Quadraspire Acrylic shelves (cryo'd legs) acrylic Response Mini under mains block.
    Speaker cable Chord Rumour (Cryo'd)
    RCM Okki Nokki
    https://www.facebook.com/groups/1586...homepage_panel
    I'm John.
    Thanks all.....
    I thought that would be the general consensus.
    John
    Teac A-3440.
    I'm Deleted.
    A jewellers ultrasound cleaner is a bath of water, usually with some cleaning additive, which is agitated with high frequency vibration (also sometimes heated) - it's not a good idea to immerse a cartridge in water (or any liquid) so, no, it's not a good idea to use a jewellers ultrasound cleaner on ones cartridge.
    Account Deleted
    Think he was talking about a stylus. Dont fancy it personally due to the glue holding your precious tip in place being affected. The at sonic platforms are a different thing and some folk liked them. Think its been said b4 that keepingvthe stylus clean by keeping your records clean is the answer.
    Imeersing the diamond would be OK, it simply carbon. The cantilever may rust and the glue fixing the diamond to the cantilever may work loose via cavitation. Personally, I'd avoid it.
    PRE
    I'm Deleted.
    You would find it difficult to immerse just the diamond - I guess it could be done but would be fiddly to set up.
    Account Deleted
    I'm scott.
