I suspect the Nagaoka is higher compliance. The arm mass may not have been enough for the rather low compliance Denons.
I'm Wolfeschlegelsteinhausenbergerdorff.
It did come with an additional weight which I tried with and without, still boomed away merrily with either
But for the price of the Denon 110, it is a very good cart for that money, it was just no way as smooth and detailed compared to a Nag, which for my ears was'nt quite right.
The DL-110 is fine at the price but I have to admit, I far prefer the DL-160. More refined and much quieter on surface noise.
There's one high output MC nobody ever seems to think of. The Goldring Eroica H. I've not tried one, but if it sounds anywhere as good as the low output LX version, it should be very nice indeed. I do own the Eroica LX and like it a lot. It's very musical.
SAE 1000LT made by coral in the '80s and can still be found, 2.5mv so a 1:2 step up would make a big difference as I found. But better on a medium to high mass arm. But use a headshell weight and more weight on the counterweight and it will sing. I have a spare you could try. Arm/cart matching is key along with cart/step up matching if using MC into mm stage.
IMHO I would have thought the Denon DL-110 would work well in the Technics from an arm mass resonate point of view.I have had a DL-110 for some time using it in a Rega RP3 and found it dynamic and fun but a little lacking LF weight and in solidity of the images. Still a great cartridge though for the price!
Good luck with your search!
