Anybody purchased one of the cheap tube amps off the net or Ebay ,if so what are they like?
Mark
Mark
Nad C315,Nad C515.Tannoy F1s,Pro-ject-USB Dac
Pro-ject headamp ,Chord Crimson/Cobra2
I bought a Yaqin MC10L, off the 'Bay but a private sale not a chinese/hk import.
Now I'm no expert, but I have to say to my ears it sounds bloody good, even stock. Plenty of power and a gorgeous wide soundstage with excellent tonal quality. I'm sure that tube aficionados will be spluttering into their tea right now, but for the £175 quid it cost me I think it's a good low cost entry to the world of tubes. I figured that if I didn't like it I may loose £25 quid selling on.
Now for the caveats - there have been some reports of 220v models having problems with UK mains, which can go up to 250+ volts in some places. Problems range from not working slight inconvenience to worrying incendiary tendencies. Replacing transformers with pukka 240v ones is expensive (£150 ish AFAIK) but there's a step down transformer I saw advertised for around £80. However, what it sounds like is anyones guess. My Yaqin has 240v on it and has so far, touch wood, been reliable. I don't leave it on unattended though - as much for the cost aspect as reliability worries, but I understand you shouldn't leave tube amps anyway.
I've tube rolled with some cheap (but reportedly good) russian ex-mil EL34 replacements with interesting results; not better, just different. Will have to try input tubes next.
So - if you can get a good one (240v compliant) there are some bargains to be had IMHO but caveat emptor, as ever!
Have fun!
Jason
Before you criticise a man, walk a mile in his shoes. Then, when you do - you'll be a mile away. And have his shoes.
Wavy grooves go thru a RigB 540ML on an SL1500C. Digits stream from a cheapie CDP and a Sonos, into a Yamaha 803D driving Kralk Audio little 'uns. I used to have a Linn but I'm better now.
Oh and I forgot - I'd be wary of buying from HK as the shipping charges can often be astronomical. I saw an MC10L for £150 but the shipping was over £200 - and you'll get stung for import duty if your unlucky.
I'd look for a secondhand UK sourced model. Ask the right questions of the seller and you should be fine.
Jason
The Mr Liang 845 SE is a very good amp.Built like a battleship,and good quality components.
I bought a Yaqin MC 100b second hand from a UK seller on ebay and I love it. It had original Chinese valves but I did a bit of rolling and ended up with Russian Electro Harmonix all round.
I run mine off a Variac variable transformer (210v) because UK mains was producing 7.4 volts across the KT88 heater pins (should be 6.3) with a bias of 600mv.
It sounds great IMHO. I for one will never go back to SS (previously had a Cyrus 7)
Cheers
Alan.
What are you after Mike?
Audioromy FU13 of course!
Yep, done that from kits and a 'cloned' phono stage. But the above is SO cheap I couldn't even buy the parts for the price. I'm treating it like a (probably not very well) ready built kit. An 'organ donor' if you will!
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
