Wondering about the rpm variance. My old Thorens tachs 'perfectly' ... Still.
Thickness of the rubber belt impacts on Rpm though... totally counterintuitive, but True.
An Oem belt might be the RPM solution?
Could one fit an earlier sub-platter/spindle ?
Never a big fan of the ones that had a pointy end rather than the earlier captive ball bearing
Danilo,
I've got the RPM down to 33.7 rpm which is still some way away from 33.3rpm this was achieved by simply cleaning the belt and platter. My new belt hasn't arrived and I've still not set the suspension up properly so I think I should be able to improve on 33.7rpm!! This is only a fun project and if it runs a little quickly that's ok.
I doubt you would hear that tbh.
Only a very minor update tonight, the electrics! This TD160 is about as simple as it gets. Basically I have the on/off switch and then the 33/45 selector. I firstly tested the 3 resistors in the little white plastic box, this is the rectangular box on the left of the picture below. All resistors tested within 5% tolerance of the stated values with the TD160 manual, so I'm happy and whilst this might explain why the TD160 runs a little quick I'm happy that I only had to get my multimeter out and not the soldering iron.
The next thing to be dismanted was the 33/45 selector.
Solder joints looked to be in fantastic order, no loose wires and both 33 and 45 rpm work when requested. I decided to dismantle and clean anyway.
Putting this back together again was a complete PITA! I did eventually manage to get it all together again.
That's it for tonight. Tomorrow's update is base board upgrade! Till tomorrow, see yeah.......
Most non vernier decks like thorens run slightly fast. they are designed that way
BASEBOARDS BASEBOARDS BASEBOARDS!!!
The standard baseboard supplied by Thorens is pretty flimsy. It's 3mm chipboard and has more holes in it than a Swiss cheese.
The feet are also pretty useless, they are simple rubber feet with a small hole in the middle which hides a 3mm by 30mm screw that fits the baseboard to the TD160's plinth. Over time these feet warp and can lead to the deck being unlevel.
Thorens realised the baseboard was pretty poor and offered a thicker upgrade which was also included in the TD160 super, the feet unfortunately remained. The interner usually suggested replacing the original baseboard with birchply or MDF. I choose MDF due to the additional weight, easy ability to drill and better finish when spraying with paint. I hate working with birchply.
I used the original baseboard as a template and simply cut a new baseboard, this was an old piece of MDF salvaged from the garage. All holed were filled in with wood filler. I wanted the ability to level the TD160 so I found some spiked feet and fitted them to the new baseboard. I also decided to use x4 35mm 4mm screws which are beefier than the old Thorens offerings and should hopefully improve the union between the baseboard to the plinth.
The baseboard was sprayed satin black.
BASEBOARDS PT2
A close up of the new thicker improved baseboard with beefier screws, adjustable spiked feet and 12mm MDF.
The new baseboard fitted with just one hole for the power lead, the baseboard will be modified when I purchase a tonearm for the deck.
A final photograph showing a front on view of the new thicker baseboard.
Tomorrow's update details replinthing the TD160.
I'm Kai.
A Thorens with the right (original) belt should run spot on, I don't think they were designed crippled from the get go As they didn't use a standard size, the original belt is the only one I've found with the thickness just right. All the aftermarket belts I've seen have been either too thick (running fast) or too thin (slow). Haven't tried the Thakker belt though. After two different aftermarket belts I figured might as well get the original since it will last years anyway.
