Hello,
I recently got a technics 1200 mk II from a friend and there are a couple of issues with it.
First, the cue lever doesn't work and I was told by my friend that it's an expensive procedure
to fix it so I forgot about it and cue by hand.
The height adjustment wheel is stuck and this is something that needs to be fixed especially if I want
to use a cork mat that I bought before checking that the vta doesn't work. Now I wouldn't like to spend
money on it if it is an easy task to do on my own so I would like your advice on it.
I found this video on youtube and I'd like to ask you if it is safe for me to try and do it.
https://www.youtube.com/watch?v=_xJs7J1RViU
Thanks
