So there's a hybrid head amp in the KIN?
Hunter S Thompson
Not a separate head amp as such, but the KIN is a hybrid design.
Well there is definitely something gelling here.
This valve head amp has been built as a bit of an experiment but it's blowing my socks off
It's remarkably low noise and there is a bit of a hum (probably need a quieter heater supply) but you don't hear it when the music is playing.
I've been spinning some albums from Dire Straits and a Strauss Gala on Decca (very well recorded) and there is a real wow factor.
Nothing I can really describe that will make much sense unless you hear it, but there is a better placement of instruments and a greater fullness to the whole sound.
Not something I really expected with a change of head amp/input method, but I'm enjoying it immensely.
Valves doing their magic again.
I'm Nick.
I did say some time ago that a valve is the best by far, if you can get the noise down enough :-). TBH, one of the reasons I designed the reference phono stage with its 53dB of gain, its front end is just about quiet enough for a 0.3mv cartridge directly into it. Some hiss, but its less than the noise floor of clean vinyl. No hum of course, the two box layout and shunt regs sort that. I would suggest you try the power supply separate from the valves. Chokes are good things in power supplies, but can be a mixed bag for phono stages as they will emit a fair amount of RFI.This valve head amp has been built as a bit of an experiment but it's blowing my socks off
Nick.
Cheers Nick
No doubt I'll continue to meddle with it.
That's what it is James, magic.
I've cured the hum by fitting a steel shield between the valves and the PSU end
Been doing a comparison between the cascode JFET MC input on the KIN and using the valve head amp into the MM input (direct to the first valve).
There is a difference and neither is bad in any sense, but the valve head amp offers more space and definition to my ears.
YMMV
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Yep, I'd buy one!
Hunter S Thompson
