Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Help - Interconnects to test
    I'm Rob.
    Do you like the cable or more to the point what it does for your system? If so, what does it matter what other people think? If I said it was rubbish, would it then colour your view of whether you like it or not or whether it fits with your gear?
    I have had dozens of commercial cables over the years and a lot that I have made myself. The last commercial cables I bought were years ago and the likes of Chord (Cobra) Precious Metals (don't know if it had a name) QED entry level and better and Cable Talk etc etc.
    Initially you think it sounds better/different/better match? If I was asked now to identify a particular cable I wouldn't have a clue. Yes, I have become very cynical and if it transmits a signal and I hear music, then.......job done. With hindsight it was undoubtedly multiple episodes of that Hifi soap "The Emperors New Cables"! Watch it on catch-up in a few years time
    https://youtu.be/ZCBe7-6rw4M
    I'm Richard.
    Quote Originally Posted by Puffin View Post
    if they are not good I would throw it out and do not make same again...simple as that. I want someone who can test and give honest opinion regardless the price....
    Nothing else
    I'm Kevin.
    If you are happy with it, that is all that matters.
    Kevin
    I'm Richard.
    those are not for me thats why I would like to have opinion from people who knows stuff
    Trust your own ears . If you think it does the business then they are likely good, BUT as you say, or imply, its good to get a second opinion.
    I'm Kevin.
    You sound like you are planning on selling them?
    Try a few different cables and do a comparison.
    If you search the forum you will find that other people have already used this cable.
    Kevin
    I'm Carlos.
    I have bee using the same cable (LoCap) & exactly the same plugs in my system for over a month now. I have been very happy with them. (pic below)
    Mine are 55 p/F per metre, I am only using 0.4 metre - some people say short is good, but I have also read that slightly longer is needed (I have no idea), also I have been running them in one direction only (reading the cable text from source to amp).
    Here are the details between the different Cap cables:
    Lo-Cap 55: 55 p/F per metre. Low capacitance figure gives low high frequency roll off
    Flat-Cap 90: 90 p/F per metre. Mid range capacitance figure gives average high frequency roll off
    Hi-Cap 125: 125 p/F per metre. Higher capacitance figure gives more high frequency roll off
    I hope that helps a little Richard? I have not made up any Hi-Cap cables to test against (like Mark did), but I guess that any difference would be more apparent in the longer cables version that you have the 3 metre one (does that make sense?)
    It would be useful to know what lengths of LoCap & HiCap Mark (YNWaN) tested before.
    I am currently trying to make up a different set of interconnects with a 'new' style of cable, I will be able post a thread in a few weeks (I am away from home for a while)
    My ears aren't great for very subtle changes & short test periods, so I am going to try something completely different next, for my interconnects.
    I'm Deleted.
    Default Help - Interconnects to test
    I used one metre lengths. These are the ones I made:
    Low capacitance one on the left and high cap on the right.
    Account Deleted
