Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 143
Thread: Fuse
    Default Fuse
    How does a 'special' fuse improve your hi-fi? Is it snake oil/bollox?
    I don't know. Are they directional and need burning in?
    Some would say "yes" and "yes they do". Do you really want to spend £25 a pop?
    some say burned out ones sound best
    If these are directional and you burn one in the wrong way round, are there consequences?
    Like it!
    Yes, you have to change the direction of the circuit breakers in your CU.
    I have had some strange things happen with fuses some folk would not believe. I had a slow blow fuse go and replaced it with a very cheap Maplin fuse and my system sounded quite a bit better after especially dynamics but I can't explain why.
    I then got very interested in fuses and bought some expensive types but they were no better
    But surely the fuse would only be correctly directional for one phase (half) of the 50Hz mains cycle and reverse directional for the other possibly?
    Has research has been undertaken to look into the effects of this?
    I'm Clark.
    Thats where the dipolar fuse comes in handy as is alleviates those bipolar moments
