I'm Stephen.
Hi guys and thank you for your input it is very welcome. I be off to work now. So will be offline. Please keep the ideas and info coming.
Thanks
Dynaudio Audience 52's
SVS SB 1000 Sub,
Rega brio R AMP
Rega DAC
Rega planar 3TT
Grace 707 tonearm
Nagaoka MP200 cart.
I'm Stephen.
Steph,
What design software do you use?
No doubt you could export your model in various formats and maybe someone could help out with the FEA calcs if need be?
Inventor and Pro-E guy here, but dont have the facility to do FEA.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm Deleted.
I should perhaps add that my opinion is FEA is no magic bullet and many of the results it gives can be predicted using experience and applied knowledge. In addition, like any investigative tool, it is only as good as the quality of the input and the subsequent interpretation of the results.
Account Deleted
I'm Stephen.
Hi Gaz, Ok dont laugh OK? I use Sketchup I use it professionally for product/landscape and Architectural for about 8 hours a day. I always feel I must justify using this medium but its actually very powerful ( I used to use 3DS Max) You have me thinking though there is a plugin called "sketchy Physics" that may do the trick. And yes i could transfer that to just about any format.
SVS SB 1000 Sub,
Rega brio R AMP
Rega DAC
Rega planar 3TT
Grace 707 tonearm
Nagaoka MP200 cart.
thanks,
i made an ebony arm board for my AR turntable before i went to the lp12,it made a big difference over the standard one,i also tried lacewood, acrylic and an mdf aluminium sandwich.the ebony one sounded the best,i may make one for the lp12 ,if i still had my wood working machines id make a matching plinth too.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm Deleted.
Did you try aluminium on its own, without the MDF element? The armboard I currently use in an aluminium/aluminium sandwich with a viscoelastic compound joining them. Before that I used a very similar design but made from carbon fibre and before that a carbon fibre component similar to that used in the chassis.
Account Deleted
no i never did,the aluminium sandwich one sounded awful so i never persevered .
My System
John Wood KT88 Amp.
I'm Deleted.
I have found that laminating materials can give very different results depending on the precise specification of the materials and implementation.
Account Deleted
