The multi plug Marco suggests is pretty good, I used one for a good few years.
I now use a multi way IEC distribution block which has 10 inputs and a single 3 pin plug that goes into the wall socket.
So all my appliances have leads with an IEC male plug on one end and an IEC female plug on the other end.
This takes multiple fuses and the crap three pin plugs they are fitted in, out of the circuit.
All my kit has low (and appropriate) value fuses on-board to protect it.
The fuse in a safety plug is there purely to protect the power lead from going up in flames, should it get trapped in a door etc and short your ring main circuit, which caries more than 13amps. As long as you have one fuse at the head of the lead going into the wall socket, this is covered. You must of course make sure your total current draw is less than 13 Amps, but that is a lot, my whole system only draws 8 Amps.
If you look at the Pro gear there are some nice 19" rack mains conditioning units for DJ's and Studio use with 8 or 10 IEC outlets on the back. Check out some of what's available at somewhere like Studio Spares. One hear for less than £100 https://www.studiospares.com/Cables-...B10_388290.htm There are models without the DJ down lights fitted, been tempted by these myself.
