Results 11 to 20 of 38
Thread: changes
    I'm paul.
    UPDATE:
    Got hold of a Linear PSU for the laptop. Zero-Zone L164-30, Ultra Low Noise. This does 'seem' to affect the perceptible audio sound. Not only does it sound sharper and clearer, but also seems to alter the 3D spaciality: makes wider & deeper but also tighter at the same time.
    ARCAM FMJ-A19 + Tacima CS947, Tannoy DC6T Speakers, Tannoy TS10 Subwoofer + Tacima CS947, Sennheiser HD 558 headset, Arcam Miniblink DAC + iFI iPOWER, HP Pavilion G6* - 2382sa D0Y14EA#ABU + Creative BT-D1 [+ Azio BTD-V401]; [*using onboard battery for music listening]. + Audio Software [Room EQ Wizard, Equalizer APO, media players]. I also have a Creative Cambridge DTT2200 5.1 System, & Denon AH-D320 Phones.
    I'm paul.
    The other bits and bobs:
    I'm paul.
    long dog audio LPSU....
    I'm paul.
    Decided to get another LPSU this time for the Router as I listen to internet streaming audio from various sources and it only has the noisy wall wart! So lets clean that right up with a nice "Zero-Zone 100VA 12V @6A Ultra Low Noise L163-39".
    Zero Zone Lpsu L164-30 (2).jpgZero Zone Lpsu L164-30 (4).jpgZero Zone Lpsu L164-30.jpg
    I'm paul.
    ISOkinetik ISOmain/LoRad, mains cables throughout.
    I'm paul.
    Latest set up:
    ....last change this year! So, the extremely nice Lyric Ti60 has given way to the Puresound 2A3 amp + some Supra mains cables. The difference between the 1000 Lyric and the 2000 Puresound is very subtle indeed (picking up on small alterations in the stereo field and a little more detail sonically i.e. tiny things I hadn't heard before in the mix). The OEM Chinese valves have been replaced with Sovtek outputs & NOS RCA inputs & NOS Mullard rectifiers (as recommended by Guy Sergeant).
    Audiolab M-DAC which doubles as a pre-amp + MCRU/LONGDOG AUDIO POWER SUPPLY. +
    Puresound 2A3 amp.
    MonoPulse 'S' speakers.
    REL Stampede Subwoofer.
    HP Pavilion G6* - 2382sa D0Y14EA#ABU + Zero-Zone L164-30 Linear PSU.
    M2Tech Hi-Face 2 RCA USB to S/PDIF Converter.
    Tacima CS947.
    Sennheiser HD 558 headset.
    + Audio Software [Graphic Equalizer Studio PRO 2016 + media players].
    Interconnects: Chord Clearway, QED Reference Audio 1 RCA/Phono (red), QED Reference Coaxial/RCA (purple), ISOkinetik ISOmain & Supra LoRad 2.5 MKII mains cables throughout with Busmann Gold Fuses. Chord Speakon Connector Cable.
    I'm paul.
    Changed Sovtek for PSVANE 2A3 C
    I'm paul.
    So, the PSVANE turned out to be a bad move as two of the valves went 'bad' after just one week! So instead of doing a 'like for like' exchange, because I wasn't impressed with the build quality, the PSV's were ditched in favour of 4 matched RCA NOS (1940's) 2A3 black plates in what can be perceived as an even higher upgrade (i.e. cost twice as much as the PSV's).
    I'm paul.
    Also added:
    The Original and the Best 'EPS Ultrapure'
    Silver Plated Range of Mains Connectors
    Manufactured by The Missing Link Audio... innovators not imitators
    Most audiophiles will know The Missing Link researched and developed the very first Silver plated mains connectors for audio in the year 2001
    The 'EPS Ultrapure' Range are not the cheapest they are simply the Original and the Best
    The original research that lead to the popularity of the Silver plated Audio mains connectors was pioneered by The Missing Link
    Their products are now widely copied although sadly the performance of standard Silver plated products can simply not compare
    Since then the Missing Link have constantly researched and perfected their range of Ultrapure Silver plated Mains connectors
    The chemistry involved in the development of the Ultrapure plating system that produces the quietest connectors is a closely guarded secret
    The result is the Lowest Contact Resistance mains connecters available today. This fact is backed with genuine measurement data
    The Missing Link is the only company to offer this measurement to back their claims and this is your guarantee of quality
    The Missing Link - innovators not imitators
    ________________________________________
    Latest Data From The Missing Link Audio
    ~ The EPS-100 ~
    Audiophile Quality Unswitched Double Wall Socket
    The Missing Link Ultrapure System
    ~ The World's Quietest Mains connectors ~
    Generated contact noise caused by contact resistance causes distortion to the 50 cycle wave-form degrading the quality of the mains - this is a fact. that's why The Missing Link were the first company to introduce Silver plated mains connectors to the market over 12 years ago and have continually improved this process using their own chemist to produce the highest purity plating possible known as the Ultrapure system as used in the full range of Missing Link power cables and connectors as standard. the test equipment used for development can measure contact resistance down to 1-10,000 of an Ohm + - 2% at ISO standard.
    The Missing Link - Silver Plated UK Double Wall Socket Unswitched.jpgThe Missing Link - Silver Plated UK Double Wall Socket Unswitched2.jpgThe Missing Link - Silver Plated UK Double Wall Socket Unswitched3.jpgThe Missing Link - Silver Plated UK Double Wall Socket Unswitched4.jpgThe Missing Link - Silver Plated UK Double Wall Socket Unswitched8.jpg
    I'm paul.
    Coming Soon....
    Details
    The Teddy19/3 power supply can be used to replace the small AC plug-in power adaptor that comes with many audio equipment, PCs, routers, NAS etc, and provides significant improvement in sound quality.
    The design is based on the experience gained with the TeddyCap family of power supplies for Naim Audio equipment, and uses the same technology.
    Sound
    In general, you’ll experience more clarity, tighter bass, more detail, better dynamics, natural voices, better soundstage etc.
    Performance
    The small power supply which is provided with most types of equipment is based on a technology called Switch Mode. Using this technology it is possible to create small, efficient, and low cost power supplies. Unfortunately due to their method of operation (high frequency capacitor charging), these power supplies are also very noisy, causing degradation in sound quality. As an alternative, several after market power supplies exist which are usually based on Linear Regulators. These regulators provides an improvement over the original power supply but as can be seen on the graph below are still limited in their performance.
    The Teddy19/3 power supply is based on a superior regulator called SuperTeddyReg and provides a significant improvement over linear regulators.
    The following graph shows the noise level measurements of the original wall wart power supply (red line), an alternative power supply based on a Liner Regulator (blue line), and the Teddy19/3 power supply (black line). The brown line is a zero Volt reference which is actually the measurement equipment internal noise. As can be seen the Teddy18/2 power supply noise level is very close to the zero Volt reference.
    Interconnects
    The Teddy19/3 power supply is equipped with a high quality cable made of silver plated PTFE insulated wires. The cable capacitance is around 13pF/ft., and its resistance is also very low, around 10 milliohm/ft.
    In a Nutshell
    The power supply has a major role in sound quality, in many cases even more than the audio circuit. Actually several high-end manufacturers consider it as part of the audio circuit design, and the same equipment whether it is an amplifier, a CD player, or a DAC will sound totally different with or without a good regulated power supply.
    Ideally the power supply rail should consist of only clean DC. In practice however, every power supply, including batteries adds noise to the audio stages. Any noise on the power rail translates into distortion, coloration, reduced sound stage, and a sound which is less natural.
    Most regulated power supplies today are either Switch Mode Power Supplies (SMPS), or linear power supplies. Our power supplies are based on the SuperTeddyReg, a different technology which has proved to be far superior for audio designs.
    Linear power supplies, such as those used in Naim power supplies are based on a transformer, rectifier, smoothing capacitors, and a linear regulator. When the AC at the output of the transformer is rectified and smoothed, a ripple is still present on the DC rail. This ripple has the form of a saw tooth which translates into noise at all audible frequencies and has a negative effect on the sound quality. The better the power supply can filter this ripple the better the sound will be. To get an idea of how much the power supply can affect the sound quality suffice to mention that almost all Naim preamplifiers are based on the same amplification circuitry and differ in their ability to connect more or better power supplies.
    The amplitude of the ripple mentioned above decreases with the size and quality of the smoothing capacitors being used. Naim Audio uses a brute force technique for the HiCap; they use a 500VA transformer and rely on large low ESR capacitors. Not only that this technique is less effective in noise filtering, but over time, due to their chemical construction, the quality of these Electrolytic capacitors decreases (ESR increases), and as a result the ripple increases. This is the reason for which Naim power supplies require expensive re-capping every 10 years or so.
    The most common way to reduce ripple is to use a linear voltage regulator such as the LM317. The core of a linear regulator is an operational amplifier which monitors the output voltage and correct it using feedback. In order to reduce cost, most monolithic linear regulators, including the LM317 used by Naim for their power supplies, make use of a simple operational amplifier which generates its own additional noise. According to the LM317 datasheet it has a typical output noise of 0.003% of the output voltage. For an output voltage of 24V the output noise will be 0.72mV, not negligible...
    In addition, all linear (feedback) regulators, including the superior Jung SuperRegulator, have a limitation which is inherent to the way they operate, they can only fix a problem after it occurs. Since the speed in which they can fix the problem (regulate) is constant, their ripple rejection capability decreases with frequency. The LM317 has a ripple rejection of around 80db at 50Hz, which drops to merely 20db at very high frequencies (note that a -60db difference means x1000 times less!!!).
    Switch mode power supplies, such as the small wall-wart power supplies provided with the Logitech Squeezebox or with many popular DACs, are based on switching technology rather than transformer/rectifier/bridge combination. The idea behind these power supplies is to charge a coil/capacitor at high frequency and use the energy they store. The advantages of this technology are numerous which makes them very popular. They are small, efficient, low cost, and they are readily available from many manufacturers (mostly in China). The main drawback of these power supplies is that they are noisy, very noisy... Not only do they have a high level of high frequency noise on the DC, but they often inject high frequency noise to the mains which may impact performance of other hi-fi equipment. In short, less than optimal for high-end audio equipment.
    The SuperTeddyReg
    The regulator is the heart of the power supply. The TeddyCap and TeddyXPS power supplies are designed around the SuperTeddyReg a regulator that has been developed especially for high end audio circuits and surpasses any regulator that we have tested so far. The SuperTeddyReg is an evolution of the TeddyReg and provides even better performance. The SuperTeddyReg is also offered as a small independent circuit to the DIY community and is being used for a large variety of applications.
    The innovation in these power supplies is the incorporation of a very effective low-pass filter that in conjunction with a voltage regulator provides a theoretical (impossible to measure with conventional equipment) ripple rejection of more than 120db over the entire audible spectrum and above 1MHz. This powerful filter allows using smaller transformers and smaller smoothing capacitors. Since it does not rely on large smoothing capacitors to eliminate the noise, it does not require re-capping if the quality of these capacitors decreases.
    Smoothing capacitors are usually in the order of 4700-20000 uF, the SuperTeddyReg filter stage uses much smaller capacitors. The advantage of using smaller capacitors is that capacitors other than electrolytic can be used. Electrolytic capacitors are limited in their ability to filter high frequencies above the audio spectrum, and have leakage noise. Our power supplies make use of a combination of Tantalum, and PPS capacitors capable of filtering very high frequencies (over 1MHz). Surprisingly, filtering high frequencies even above 100 KHz is clearly audible.
    The following graph show the difference in noise level between a good quality Switch Mode Power Supply, a Naim SuperCap, and a TeddyCap mk3
    As can be seen on the graph, the Logitech Touch PSU (pink line) which is a Switch Mode Power Supply is very noisy, the Naim SuperCap (red line) which is based on a linear regulator is still relatively noisy all over the audible spectrum. The TeddyCap (blue line) has a much lower noise level, and outperform the other power supplies by far. It is actually very close to the 0 Volt reference (black line).
    Comparing with the original Naim power supplies, these power supplies will provide a higher level of resolution, better transparency, more detail, larger 3D soundstage, deeper and more controlled bass:
    "Bass is tight and very deep, with the higher scales well defined and vocals crystal clear. Drum solos are amazing - you can now actually define the drum being used. It retains, but more so, even enhances the 'PRAT' that Naim are renowned for." Read more testimonials...
    Implementation
    Obviously, to achieve this level of performance a larger number of components is required, and high attention is required in component selection. Many listening hours showed that every capacitor type and value has an impact on the sound. PCB layout has a major effect on power supply performance too. Component placement and signal routing are critical. Several cycles of design, prototyping, and measurements were needed to achieve the best results.
    .....to replace the Zero-Zone Lpsu L164-30 (for the: HP Pavilion G6-2382sa D0Y14EA#ABU).
