Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: ebay Gainnclone - Too good to be true?
    I'm Rob.
    Default ebay Gainnclone - Too good to be true?
    Looks like a lot of goodies for the money.
    http://www.ebay.co.uk/itm/Assembled-...AAAOSwa-dWmKra
    https://youtu.be/ZCBe7-6rw4M
    danilo Guest
    More Bits and Bling in that contraption than in my TV set.
    There's over a 100$ worth of bits on there alone.. IF they were Genuine
    Want a Genuinely "good" Lm3886 amp??
    Buy this and Likely need never again get the urge to buy alternate amplifications.
    http://www.neurochrome.com/modulus-86-rev-2-0/
    PS; read the man's resume If you need credentials for the design work
    Congrats on the 5000th post Rob
    Surprising what you can get from China for very little money. I'd say go for it, nice that it includes the anti-thump/speaker protection circuit as well.
    I'm Rob.
    Yes, 5,000....I must get out more
    I have made many GC's, a BrianGT one, several LM3886 and 3875 point to point and one bridged stereo 3886 P2P (you don't want to see the rats nest of wires underneath!)
    This just peaked my interest, and yes having the protection circuit is a unusual bonus for these cheap boards. Heatsink? Oooh getting a bit thin on the ground, I might just nail it to a dustbin lid....in case it is rubbish
    I'm Rob.
    Quote Originally Posted by danilo View Post
    Interesting read and I am sure it is very good. I have got old and lazy and can't be bothered any more to source all the parts needed
    I'm Ari.
    http://www.ebay.com/itm/Assembled-LM...8AAOSw7aBVCmdK
    Here's a slightly different take with OPA2604 .
    The price is so good , it's probably worth checking out .
    I've tried various LJM kits , with very good results , and every time from this seller :
    http://www.ebay.com/itm/DIY-KIT-LJM-...item2c92433554
    I've tried the following :
    LJM L25D ( IR class D ) - very close to IR reference circuit , amazing performance with 400VA torroidal + dual rail supply ( 6x 10 000 uF Nichicon 80V ) ; or with 2x Abletech 53-0-53 SMPS ( one smps on 2x modules blew smps )
    LJM L20 ( Class AB ) - excellent with 400VA torroidal + dual rail supply
    LJM L25 ( Class AB with onboard opamp pre ) - excellent with 400VA torroidal + dual rail supply
    I see that the seller only sells the L15D Pro and L20D Class D's now . I'd like to get these in future too . I can highly recommend the linear dual-rail PSU option . I built my own , but he sells those too , probably cheaper than building your own . SQ with linear supply sounds effortless and is completely neutral . Simply amazing .
    I'm Rob.
    I think what Colin says in post #216 regarding the cost of the innards of the TQ amp is something I am sure a lot of us have suspected for many years.
    I have built a stereo Mosfet LJM L12 which has been running daily and satisfactorily for over 6 months. Sounds very good. I have another board so that I can bridge them both at some stage.
    I'm Ari.
    Hmm - I see there are also L12-2 versions selling - those are probably already bridged as no 4 ohm ratings are given . I tend to stay clear of designs that can't handle low impedance dips and generally try to use slightly lower voltage in suggested range , keeping them cool and unstressed .
    I just checked the LM3886 datasheet - looks impressive enough http://www.ti.com/lit/ds/symlink/lm3886.pdf
    I'm rupert.
    I have been eyeing that amp for a while. Have you built one yet ? If so, does it live up to its reputation ?
    Greets
    Ru
    PS. I have built a couple of Gainclones from Chipamp and Peter Daniel and also a LJM L15D Pro all of which I'm very fond of.
    I'm rupert.
    Quote Originally Posted by Ari View Post
    Do you pls have a link to the rectifier board you used ? Thx !
