Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Connecting a Turntable to a TV
    nigsy116 Guest
    Default Connecting a Turntable to a TV
    Hi all;
    1st post here so hopefully in the right forum; appologies if not.
    I have a Sony PS-LX300USB turntable (supposed to have built in pre-amp stage) and a new Samsung 48" curved 4k TV - UE48JU6500KXXU.
    The TV has L/R audio inputs on the rear but when I connect the turntable all i get is a 'weak / no signal' message. I wonder if this is even possible or is the TV also looking for a video input and ignoring the audio stream?
    The TV sound outputs to a Sonos system via optical; just in case any one was wondering why I would want to listen to vinyl on TV speakers!!
    I'm Richard.
    are you sure you have RCA audio Inputs?
    Can you take a photo of the rear connection panel a post it?
    edit: and if so on what Input are these? AV?
    I'm Johan.
    There is a button on the rear of the tt. It lets you switch between "line" and "phono". Make sure it is set to "line".
    Not sure this tv has audio rca inputs... Its not mentioned
    I'm Neil.
    Its not unheard of, composite or SVHS input and left and right RCA ins for that video connection, but it is less common these days, more common for there to be an audio out.
    Regards Neil
    Think it mentioned componet in... But if the tt has a switch for bypassingvthe internal amp then that sounds like its the likely culprit
    nigsy116 Guest
    Here's an image of the back pannel inputs. I'm assuming the bottom 2 are L/R in?
    https://drive.google.com/open?id=0By...VlLeUZRNWktbU0
    Work firewall won't allow me to upload image
    nigsy116 Guest
    Quote Originally Posted by Kvaal View Post
    Yep tried both.
    I'm Neil.
    So there will be a sound element for that video input. I think you are probably right.
    Regards Neil
    I'm Neil.
    Quote Originally Posted by nigsy116 View Post
    Yep tried both.
    The TV will need to be switched to the correct input. If it is, I guess there might be a set up option in a menu in the TV. That might need tweaking. It should work. If not then maybe a video signal needs to be sensed on that input for it to work, but if so I haven't come across that before.
    Regards Neil
