Page 63 of 171 FirstFirst ... 1353616263646573113163 ... LastLast
Results 621 to 630 of 1701
Thread: Macca's Lash Up 2: Lash Harder
  1. #621
    Sarin?
  2. #622
    I'm Justin.
    I decided to calculate the masses for the diaphragms of the Quad 57 ESL.
    The bass panels are made of 12um thick SARAN (polyvinyledine chloride, density 1.63g.cm-3), 30cm wide by 58cm high, so their mass is 3.4g.
    The mid/treble panel is made of 6um thick Mylar/Melinex (polyethylteraphalate, density 1.4g.cm-3), 15cm wide by 58cm high, so the mass is 0.73g.
    So the mass of the bass panels is heavier than I thought. They are consideably smaller in size than that of your Apogees.
    It also shows that Wikipedia is not infallible!
    Good work. Actually when I said a factor of ten or more lighter, after I posted it I thought it was a bit unreasonably generous. You've proved that.
  3. #623
    Quote Originally Posted by agk View Post
    Sarin?
    Yes. Named after our local 'Superstore'!
  4. #624
    I bet that building has won some architectural awards. Jesus, what a mess! Was the planning officer on drugs the day he agreed to that?
  5. #625
    It was a half decent little pub twenty years ago, now gone the way of many in the area.
  6. #626
    So how are things sounding now, Martin? Have you still got the back-up amp in, or have you reverted to the Krell?
  7. #627
    I'm Neil.
    Back in the day there weren't a lot of passive's kicking around, so an active pre would be a more intended match than a passive. I have heard a fair number of folks comment that a KSA50 and Audio Research SP9 was a great match. These were just slightly before my time so I never heard that pairing or similar but some of what you are describing sounds like a miss match with the pre. My own experience based bias would be to be less inclined towards passives than actives.
    Only way to know will be to try stuff and see whats what.
    Regards Neil
  8. #628
    Just got in about ten minutes ago, not done any listening today. Might have a session tomorrow afternoon. Think I'll put the Sony CD player back in, see how that goes.
  9. #629
    Ah, out boozing again! Quite right
    So, Sony back in and retain the same amplification? Sounds like a plan
  10. #630
    Quote Originally Posted by Dalek Supreme D L View Post
    Not challenging what you're saying here, but Macca's Krell is a mid 90's 50 'S' and not the fan cooled original which I remember having a different set of virtues. The 50 S here, had a lean and precise sound to me, rather than the slightly diffuse original KSA50 which has a different circuit I think. No original Krell owner would ever think of using a passive pre with one as they'd have automatically bought an active pre, usually a KRC2 at the time, or an ARC model, the latter warming things up while retaining some clarity despite the sonic processing most of them did (the SP9 was actually more neutral as the circuit was simpler - really nice valve preamp I remember with an excellent 3-D presentation which led me to the unrelated FET based SP14 I had for a couple of years until replacing it with a Croft - cough). I had to use what I had here and found the passive fine with the digital sources I usually use - and of course I have a phono stage with a similarly high output and never played the tuner loudly (at the time, an old but serviced Quad FM3).
