Page 54 of 172 FirstFirst ... 444525354555664104154 ... LastLast
Results 531 to 540 of 1711
Thread: Macca's Lash Up 2: Lash Harder
  1. #531
    lol... meant loosen by themselves mate
  2. #532
    I'm gone.
    A quote from the Stereophile review of Martin's amp ----
    "And perhaps that's also my only real criticism: that it has lost some of the slam, the "Wham, Bam, thank you, Dan!," that characterized the original KSA-50"
    So maybe it is just one of the compromises in the amp's sound.
  3. #533
    Well there is certainly a slight 'veiling' coming from somewhere. I've had it better than this before. At a loss really. On paper everything is right.
    One thing that has been bothering me is that the plugs on the speaker cable are quite loose fit into the sockets on the Krell. although they are a tight fit at the other end into the speakers. Could this be a factor?
  4. #534
    easly, yes.
    How to sort that then?
  6. #536
    if you have an assortment of cables etc try a few plugs til you find 4 tight ones and the fit them. if they are all loos then get the sockets replaced.
    I'd suggest Nordost type 'Z' plugs. They make good tight contact and can even be opened out a bit to make them tighter.
    Like these: http://www.ebay.co.uk/itm/8-Gold-Pla...IAAOSwFJBZUScO
  8. #538
    What interconnects are you using Martin? They can make a big difference.
  9. #539
    Haven't soldered in 20 years. That's not going to happen. Will try some other cables with chunkier plugs.
  10. #540
    I linked to screw on plugs mate.
