Page 53 of 171 FirstFirst ... 343515253545563103153 ... LastLast
Results 521 to 530 of 1701
Thread: Macca's Lash Up 2: Lash Harder
  1. #521
    'Softness' is not something I've heard Krell amps accused of Martin.
  2. #522
    Or JM Lab speakers either....
    Who knows, maybe it is my hearing or something With the Sony in it was just too smooth, like 'B&O lifestyle' sort of sound. Super clean even at high spl and dynamic too, but just lacking a tiny bit of bite.
  3. #523
    Should also point out that the room is quite heavily damped, possibly more so than is optimal. In theory, the speaker end should be live and the listening end damped, which I used to have, but a large amount of clutter has accumulated at the speaker end over the last couple of years.
  4. #524
    I'm Peter.
    Hi Martin.
    Not sure how the JM Labs are constructed, but whenever my system starts to seem a bit lifeless for no apparent reason, I usually try tightening up the bolts holding in the drivers ... can sometimes make a real difference ime.
  5. #525
    Good tip Peter, but I just took a look and they have some weird sort of fixing, not just normal screws or bolts. Never seen anything like it. Got nothing that will fit them anyway. Nothing is ever straightforward.
    It is only a very slight 'trait', I'm not fretting over it. But there is still some work to be done here.
  6. #526
    Having looked at a few rather difficult to make out online photos, I suspect the driver securing bolts could be 'Torx' type.
    There are two types. One with a 'pip' in the centre and one without.
    Like this:
    Suitable driver sets are available on ebay. Not usually too expensive.
  7. #527
    Cheers Geoff - that does look like them. But some of them look to be threaded. I don't think I can do much with them.
    Not certain this is an issue. I've tried to tighten up the drivers on speakers in the past and never encountered any that were slack.
  8. #528
    doubt torx bolts will loosen. they sually are very tight
    Never found one I couldn't undo. The door hinges on my Mercedes were held on with them. Now they were tight, but I got them undone after busting the first driver I tried.
  10. #530
    lol... meant loosen by themselves mate
