http://www.ebay.co.uk/itm/Vintage-Mi...AAAOSwKtlWlQ4l
Looks the part , shame the TT is not working
I'm Allen.
They have a habit of packing in...getting old a!d they are complicated
Thought the idea was a bit daft when they were first introduced. I can't see any advantage at all in having a vertical turntable.
Takes up less space and looks funky?
I nearly bought one of those Mitsubishi systems once - it was in Apollo (remember them?) and heavily discounted. Not the exact one Al linked to but very similar. About 1986. I was with my old man and he said a vertical TT was a stupid idea so I bought an Aiwa instead.
I'm nigel.
the seller says the arm is not lifting...I have repaired a couple of Japanese turntables of this type and vintage and the problem is always the same.
the arm is driven by a small motor...lift and traverse across the disc...the small rubber belt supplying drive turns to black goo over the years.
the last one I fixed, a TRIO linear tracker, was bought back to life using the belt from a spare computer cd rom drive...curiously this was a perfect match.
NIGE.
I'm gone.
I'm Sam.
I'm Sam.
