Have had stans upgrade swf3 chip installed now for a few months works very well indeed have done his gfu mod super caps though underneath as did not wish to disturb the oscons i had soldered in earlier.Whilst i had the case open installed the 22x 470 uf 16vdc oscon sepc caps in place of earlier bank of sep oscons as these have better esr .Why so many the values are smaller thus required this many ,however once installed and measured found total capacitance was 12,700uf caps done in paralel.will post pictures.As for the sound had to be run in overnight sounded very splashy strident on first firing up.After run the following day the dac is now superb playing discs all day hearing details on discs i know very well and being astounded .Every single source movies streamed via oppo 105d the television all sound great,i use dx3 in a horn boxes bass is fast tuneful midrange informative treble soaring all whilst being relaxing and at low levels.,should i crank up the wick all i have described remains the same just much louder, speakers feed by bottlehead modified 4 watt class d amplifier fronted by stereo coffee ldr preamp.Stanley has brought music to the masses i own the original caiman as well as bushmaster mk 1&2 .
