Hello to All,
does anybody know these speakers ? I am looking at an advert on a local auction where a pair is going for around 50 quid. They seem to have a good and professional reputation. Thank's.
Hello to All,
They're TDLs, not IMFs.
Look decent enough though. The drivers look rather similar to items Heybrook used. I'd grab them. Why not make an offer?
oops, yep... and the model is RTL not RTS ...
I'm Deleted.
TDL's 'design thing' was transmission line bass loading and the foam filled rectangular ports suggest this is the case here too. The only thing is that this is really too small a speaker to make use of a proper transmission line so it's more likely to be a kind of damped port (aperiodic).
Account Deleted
I'm Deleted.
Yeah well it's still true, physics is still physics and marketing is still wishful thinking.
Account Deleted
RTL stood for reduced transmission line - or something similar to 'reduced' anyway. Same as the RTL1, 2 3 and 4 which are still around on the used market.
Somewhere between a port and a TL but then so is any TL that contributes the rear wave to the sound.
Try working out the principles behind the IMF ALS designs. I think I can guess how they work.
These were capable of some very fruity, tight and powerful bass.
Thus in the somewhat smaller bookshelf ALS 40 Il an additional bextrene sub-woofer is fitted at the end of the line to enhance low frequency efficiency and extend the bass response below that which is typical of such an enclosure size. This extra bass unit is electrically driven via the crossover network and is of dissimilar but interelated resonance to the upper bass unit and to the length of lirie. As such, the 1 active' transmission line (ALS) is a stage removed from the slave units employed with reflex enclosures
not sure I fully get it but there you go
RTL was Reflex Transmission line
Here is the link to the brochures - Rupert is looking at the RTL1 not the RTS 1 which doesn't exist
http://www.imf-electronics.com/Home/tdl
yep, sorry, I got the title horribly wrong. Thank's for the input so far
