Older records you never have this trouble, so hink you are right, and they are making the holes a bit smaller now
Thought you liked it tight Grant?
Ps...Touche.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Hi Simon,
Since you're only down the road, if you bring me the records that don't fit, I'll drill them out for you with a purpose-made tool that I have, from Clearaudio:
http://www.needledoctor.com/Clearaudio-LP-Drill
Takes seconds, and does a great job!
I'm Simon.
Thanks for everyone's replies have tried the bic method and worked!!!,however may well take up on Marco's
Offer as some are still fighting the pen and don't want to get too brutal. ( Marco I go fishing at Bangor on Dee and sometimes see bands in Wrexham - Focus Wales, Hawkwind coming up soon so could pop by if convenient) .
Everyone's help much appreciated as being a newbie on here thought I was asking a stupid question .
All the best
Simon
Sure, Simon. Just pop me a PM when you're in the area, and we can hook up
The BIC pen method works to a degree, but it's not the best solution, as essentially all that's happening is you're forcing the blockage from one side of the hole to the other, by just pushing it through, so when you play the side of the record which the blockage has been transferred from (the side that the pen wasn't forced through), the hole will still be tighter than it should be.
With the Clearaudio tool, you're actually drilling (and widening) a completely new hole in the record, and one that's designed to fit the spindle perfectly - thus the problem is permanently eradicated!
I'm Kai.
A small round file also works wonders, if you just remember to not get over-excited with it Usually you need to make hole larger only by a very tiny amount.
This may seem obvious, but if the problem is the Thorens spindle then you may end up with loose fitting records should you change turntables.
Cheers, Jeff
You dont. I moved to a jbe and its spindle is smaller but everything fits nice and easy as it should. Tbh all my old records, of which ive many fitted the thorens ok, but stuff from say the 80's on often didnt. It isnt much but enough to make it not quite fit without banging on. Removing a tight one is harder than getting it on lol
Just use the tip of an old fashioned potato peeler, and save yourself $50!
PS if you are wondering why the diameter of the drill bit is 7.33mm, that's because the specification for the centre hole is 7.24 -0/+0.09 mm.
http://www7a.biglobe.ne.jp/~yosh/standards_table.htm
