Results 1 to 1 of 1
Thread: Update on the latest projets and creations
    Default Update on the latest projets and creations
    Having moved house and workshop and been busy creating mostly armboards recently, it's time for an update.
    Here is the latest crop.
    A pair of SL-1210 ebony armboards with SME arm fitting - bound for the USA
    SL-1210 armboard in Ebony for Mikro-Seiki arm with on board rest mounting
    SL-1210 armboard in Ebony for a Jelco / Ammonite uprated armbase - For Singapore this one.
    A spindle reduction job so that a perspex disc could be fitted over the spindle end
    Lacquered finished armboard for a JVC QL-50 deck. Had to be very accurately made to a template / customer measurements, and with recessed turned nylon bolt mounts - for Canada this one.
    SL-1210 armboard in Ebony for uprated Ammonite armbase / Jelco - For the USA
    SL-1210 Ebony for a Dynavector DV-505 arm - For New Zealand this one.
