My Monitor Audio R700 speakers, which I have loved, have a tweeter issue - one has totally packed up.
I've had little success talking about this in a hifi shop and basically been told that tweeters cant be switched out. I'm not sure I believe this and so have been trying to find out more.
I've contacted Monitor Audio and they don't have spares for this speaker any more (to old)
I’ve taken the speakers apart to see what I could about the current set up.
The resistors in the crossover has 11w 3.3ohms on it, and then it says J EXPOTUS.
The speaker spec themselves are
Frequency 55hz – 20 hzt 3db
Range: 40hz – 20 hz
Nominal impedance 8 ohms
Sensitivity 89db
Talking to a tweeter supplier in America, I've given them the dimensions and spec to see what they come back with. They have suggested a Dayton Audio RS28A-4 1-1/8" Aluminium Dome Tweeter.
What do you think? - is this a stupid thing to pursue, or do you think replacing the tweeters would work, has anyone any experience of these tweeters? In terms of physical fit they look like a perfect match so thats not an issue.
