Hi All,
I am just about to take the plunge to get some dedicated mains power to my audio room. I've done several hours of reading on this forum and would be grateful for some help choosing the best way to proceed.
So the background info. I'm in the UK. I have an extension which I used as a dedicated home cinema. The main distribution board was installed about 8 years ago and has 2 spare breakers. Luckily one of my best friends is an electrician, and is very familiar with my set up (we do movies every friday!). So all the tricky/dangerous bits will be in safe hands, and won't cost me anything
My ideal path for the new wiring is getting it outside and along the external walls of the extension, coming in at the back corner of the extension, as I want to avoid as much destruction inside the house as possible. This will require 19m runs of wire.
My initial thought was 2 separate radials using the 2 spare breakers, one radial for the power amps, one for the sources and pre amps.
But on reading threads here I'm not sure anymore!
Firstly, my electrician friend is suspicious of audiophiles and thinks 4mm mains cable will be just as good sonically as 6mm or 10mm. My reading here indicates that 10mm is commonly used. Can I give him a solid explanation of why bigger is better?
Secondly, opinions on my options:
A. Single radial + mains block
B. Two radials, amps plugged directly into wall sockets of one, mains block for other equipment on the other
C. Single heavy duty wiring out to a separate distribution board in the audio room feeding multiple single unswitched sockets
If going with my original idea of two radials, does running the 2 cables side by side for 19m cause any problems?
What type and thickness of cable?
My budget for wiring, sockets etc is ideally £200-300. If I'm going to do it, I'm happy to spend a bit extra for mid range products, but can't afford top end stuff.
Thanks,
Nick.
